Upgrade my 256 SSD C drive to 512 C SSD drive.
12 Feb 2009
N.Ireland
Hi, I just noticed that my 256SSD C drive is filling up slowly, I want to clone or copy it to a larger 512 SSD.
What is the best way to do it?
I have one of these StarTech standalone Hard Drive Duplicators BTW
Thank you.
If you have a stand alone duplicator
That should work
Or whoever is the drive manufacturer
Normally they have free toolbox software
Which includes cloning
Assuming you have a free internal port
To connect the new drive to
While cloning it
That should work
While cloning it
Thank you. If the stand alone duplicator would work that would be great.
The only thing it may depend
On the actual duplicator
Whether it resizes to fit the whole larger drive
Or just copies it as 256GB
And an unallocated partition making up
The rest of the 512GB
So you may need to go into windows disk management
Afterwards
And extend it to the full usable 512GB
By partitioning the unallocated space then merging it
With the copied partition
Some cloning softwares automatically do this
Not sure about hardware duplicators
I use clonzilla - It's pretty easy to follow
If you follow the video you can get it to automatically expand the partition to fit the new disk
