- 9 Apr 2012
Wireless subwoofer is a bad idea. Sure if it's one choice but I'd ensure the soundbar has standard pre out so if the sub blows up you can use any standard active subwoofer. Or if you find it's not capable enough you can change or add a second
A couple of the sennheiser ambeos have pre outs the max definitely has it and I think the one below that. but not the mini
When am I going to do that?
). Sound quality and effects are really good and you can usually find them at a steal as well every now and again.
