I want to run ik multimedia amplitube and cubase le initially and would require a gaming replacement for an xbox series x as I don't have the room for a tower and an xbox.
Thanks in advance for any advice.
Disclaimer: Are you intending to build the PC yourself? Please let us know what your intentions are: (1) You are building your own PC, or will have someone doing this for you (2) You want OCUK to build your custom PC (3) You want an off-the-shelf PC As computer enthusiasts, we normally...
forums.overclockers.co.uk
We'll need a budget at a minimum, plus if required: any peripherals or monitor. If not required, what resolution the existing monitor is.
as tetras said look at that template people will need more than that info to help
also worth noting that budget hardly covers the ram nowadays
what kind of music production are we talking here? i dont neccesarily mean music genre [although out of interest that might be interesting to know] more how you approach it.
im making stuff completely from scratch and i use onboard vst and plug my instruments straight in via my interface so im running guitar amplifier speaker room and effects
pedal simulations all onboard instead of just mic on a amp and cab approach which uses more system resources. and i also use vst for the drums and various other things. so a
lot more intensive than some people's music production work, less intensive than others though. admittedly using casual in the thread title is at least helpful though im guessing
your not needing stupid amounts of processing power and memory usage at least judging by that i guess.
