- 21 Dec 2019
- Planet Thanet
This drove me crazy all day today
Thought it was corrupt isos, bad flash drives, the bootable
Usb software
So if you get restart at 77%
Then Windows installation failed message (no error code)
2 fixes
Easy fix to try first
Once you tell it language/location/keyboard layout
You will have install windows or repair windows options
Ignore both and look at bottom left corner of the screen
Theres a use previous version of windows installer
Click that and see if it works
If not
2nd fix (this was what worked for me Easy fix didn't )
For whatever reason if you have multiple drives
And unfortunately i dont know what number
Of drives will start the problem
The windows installer throws a wobbler
And won't go past 77%
For me I have a mix of sata drives and m2 drives
Don't know what happens if only
Have one type of drive
So it's make image backup first just in case
Then either go in the bios
And disable your sata drives
Or if got hot swap drives just pull those out
Depending on what drives you have you may need to play
With disabling individual sata drives
I just took the nuclear option as had no patience left
By that point
So I pulled all 4 of my hot swap sata drives out
Simply because was faster than going to the bios to disable them
Retried clean windows install
Used exactly same iso,usb,software
And windows installed perfectly first attempt
So it's either too many drives in total
Or too many sata drives
Or too many m2 drives but those aren't simple
To disable
Have had the same drives a long time
Never had any problems doing this before now
It appears theres something different with the 24H2/25H2 installer
Than previous versions
Usb software
2 fixes
If not
By that point
To disable
