AMD Ryzen 7 9800X3D
  • Thread starter Thread starter Hostile_18
  • Start date Start date
Didn't it have an issue with certain M.2 drives but it was fixed 9 months ago? Not sure there are any overlasting issues with that one...
That may ring a bell now you mention it. I couldn't find anything from a quick google, but the board has served me well since a few months after the AM5 launch on a 7800X3D and now 9800X3D. Hopefully it will be fine for the 10800X3D, too.
They definitely addressed it with a bios update at some point so it shouldn't have been an issue from that point!
Is that at stock? Or with any changes to PBO?
What cooler as well?
I could get around 1375-1385 on an aircooler - up to 1426 on a 280mm AIO. This was all at -25 PBO curve and with relatively tuned RAM.
It's with -30 PBO with a arctic freezer 34 air cooler, the temps while running R24 was max 82C
Yeah that's a great score then with that cooler! You could probably bump it up a little by running fans at 100% and changing PL to motherboard but realistically you'll see a marginal gain in CB score and basically no change in your games you play.
Awesome. thanks for the help
Had a first run on Cinebench 2026 with my build, no real optimising or tweaking for a high score but a more representative view.
Here is mine :) My CPU and BCLK are tweaked, as is my RAM; honestly, the only thing I'm missing is the ability to just lock it at max clocks in games rather than varying per load. I'd prefer it to just run at max frequency full stop under load, even if not fully loaded, to reduce any clocking latency and help reduce any stuttering.
C24
C26
