Any point in an upgrade?
Caporegime
18 Oct 2002
Ireland
Been thinking about it on and off over the last few months but still undecided. Current build as in sig a 5900x 32 gigs of ram and a *9070xt (*yet to installed).
Been considering an upgrade to an 9950x3d setup, but as my current monitor is a now aging 60hz 4k panel, I'm not really sure I would see much benefit as that res is more gpu bound than cpu. Was considering maybe switching to 34x14 180hz ultrawide for the time being on my current build to let it stetch its legs a bit more at a lower res, though coming from the sharpness of 4k I'm not really sure if the downgrade in res will be palatable. Then there's talk about a 9950x3d2 coming which will probably be a small bump over the current one, but for a full platform build it would probably make more sense to wait for that and get as much performance as I can for the cash out of the box as I can't be arsed tinkering with clocking anymore.
Given memory and storage prices this is probably the worst time to get a new platform (and we don't even know how long this will last and pricing could get worse later in the year), so I'm maybe leaning a bit more towards the budget ultrawide (asrock phantom) for the time being.
/scratches chin. :o
I honestly wouldn't bother in your situation, especially given the prices of RAM right now.
If you don't need the extra cores of the 5900X you could consider switching to an X3D AM4 CPU, although at 4K/60hz that's going to have very limited to no benefits. It's absolutely worth it if you switch to a 1440P ultrawide with a high refresh however, that's the sort of monitor I'm running at the moment with a 5800X3D.
The problem there is AM4 X3D CPU's are like hens teeth right now and command a bit of a premium, but given you're on a 5900X you could potentially do a straight swap for a 5700X3D. Maybe pop in a request on the MM and try your luck? There's bound to be people looking for a productivity CPU that are currently on an X3D.
If you've some cash to burn there's some really well priced OLED ultrawides, I'm running a Phillips Evenia and absolutely love the thing, it was £450 when I bought it a year or so back.
Might even be able to get a new 5800x3d if amd resumes production of them, again a wait and see thing.
Is your monitor the evnia M2C6500? ? Looking at some reviews on youtube, 4k version at 240hz looks very nice https://www.overclockers.co.uk/phil....5-240hzhdr-tb400-usb-c-hd-mon-php-03541.html
No, it's the 34M2C8600 I believe (without digging around for the order, there's that many bloody model numbers/variants for the same things with tech):
I use it alongside a 4K 65" TV as a second/couch gaming monitor and find the two to be an excellent combination. For games that benefit a mouse/keyboard more (fps/rts and a few others) or have particularly high requirements where I'd favour higher FPS I use the Phillips. For everything else I do the couch potato mode and use a wireless 8bitdo Ultimate controller, usually RPG/Adventure type stuff that I can get away with from a performance perspective.
OLED monitors are really starting to hit good price points and are probably the best value PC gaming components we have right now tbh.
If you want to go 4K this is a bit of a gem for the price:
My basket at OcUK:
Total: £528.95 (includes delivery: £0.00)​
Yeah seems to be a lot of them with similar names, the m2c6500 appears to be the latest model in the 34" variety. Have to have a think about it.
It should significantly improve the 1% lows for much smoother gameplay.
There are a lot of exciting new monitors being announced at CES. Especially if you play older games a high refresh 4K monitor would make a lot of sense.
It's really the only area I think is shining right now for PC gamers, you can pick up a 49" super ultrawide OLED for £650 at the moment.
My basket at OcUK:
Total: £649.99 (includes delivery: £0.00)​
That's ludicrously good pricing for an OLED of that size, the only real caveat is game support and genre. You'd not want to try using one for competitive FPS but good lord when playing sims it's a vast improvement over any triple monitor setup in my opinion.
The monitors might not be as competent at things like HDR as some OLED tv's, but they carry almost every other benefit at a massively reduced cost. I know a ton of people that use 42" LG OLED tv's as monitors and still do, but you're looking at over a grand unless there's a damn good sale for the ones with good gaming features.
Agreed, but its main gaming use case is driving and flight and space sims, not FPS.
Oh god no, shy of having fish eyes it'd be a massive detriment to most competitive play outside of sims.
For general use it'll probably be a pain in the bum for a lot of games too, ultrawide support has improved a lot but it's such a niche that I'd never use it for playing RPG's or the like (outside of 1440P ultrawides).
Looking through some reviews and happened across another video that claims that QD-OLED panels are stupidly easy to scratch, basically no matter how careful you are with it. :o WO-Led is apparently a lot better in that respect but the colours are less vibrant on those panels.
You can run games “unsync’d” like we all used to do. You may also be able to overclock the monitors refresh rate and gain a little more performance that way too.
The new panels coming this year are supposed to be more scratch resistant and have less purple tint.
if your planning on keep the same GPU i wouldn't upgrade. a 5700x3d/5800x3d will give little to no performance upgrade at 4k unless you depend on FSR to get good FPS.
this is not based on ram prices but based on the AMD road map, if your happy with the way things are i would wait till next year for the new CPU's.
Grabbing a motherboard and stuff like that now as prices are up and down would maybe be a good idea.
if your gaming at 4k again a X3d chip is not always the way to go unless your using DLSS/FSR, the performance vs cost outlay is very bad at native 4k, a 9700x can keep up unless your hurting for 200fps
I went from a 5950 based system to a 9950x3d and I feel it has been one of the best upgrades I have ever done, everything feels amazing, every game an upgrade running 4k, but......there is always a but :D
I don't know what the main contributor is as I changed everything :rolleyes:
Is it the X3D giving higher 1% lows, possibly
Its it the 5080, I mean it is powerful but still struggles naxxed on some titles so I think less likely
Could it be the VRR monitor, I think it might well be a main contributor as I have noticed a similar fluid feel on my under powered handhelds that have VRR which struggle to do much more than 50fps
So maybe the upgrade to have is the monitor, VRR, super fluid feel, no tearing etc?
I was contemplating replacing my 5950X build a little while back as I felt it may be holding the 4090 back, but with one thing and another I decided I’d be better off waiting for the next gen AMD/Intel CPU’s and Nvidia 6xxx series GPU’s. Even at 4K my current setup pulls decent frame rates for smooth gameplay at max details with DLSS.
Yeah I did the same and it’s a night and day difference. Another realm of performance even.
What is it that you want more performance for?
I'm assuming with the 5900X and considering a 9950X3D2 you do a lot of long-run stuff? If you do, the difference and time saved for anything multithreaded would be enormous.
Do the odd bit of video editing occasionally and trying to get back into gaming to some extent. Just mulling over an upgrade, though might wait and see if the 9950x3d2 is coming at some point relatively soon.
