** NEW PRODUCTS ARRIVED AT OcUK!! **
Any chance you may get Corsair 5400 stock before the new year ?
@Dicehunter they landed today, hopefully you're still after one!
@Firegod we do have the new board on order and are expecting the stock to land any day now. The Christmas break has caused a bit of disruption as they should have landed by now. We only have a small allocation so may be best to pre order if you are set on one.
high chance we will list that model when it becomes available.
obviously there is no firm info on pricing, availability or anything else at this point.
Any plans to sell the upcoming asus 5090 pro art gpu?, i'm most interested in obtaining one :D
The more I look at it the more I’m tempted by it but trying to resist and wait for the 60 series(or AMD equivalent if they offer the 6080 equivalent as they haven’t with current cards), currently have the Sapphire 7900XTX Nitro+ which is almost 3 years old.
If I do get this will I need to upgrade my current PSU? Have the 7800X3D
Still no sign @rjk :(
We have had a few delays due to the weather. Everything I have been expecting this week has been pushed back unfortunately.
your cpu is good, if your playing at 1440p or 4k, for the power supply 1000w would be better if going for a 5090, that way if you opted for 60 series or rdna5 you have headroom to spare, i run a 1200w strix
I have the Alienware AW3423DWF monitor so ultra wide 1440p, not figured out how to set the 165hz mode tho.
165hz mode will be enabled in the monitors osd settings somewhere, read through the manual and you should find the option to enable it, 1440p ultrawide is in effect almost 4k so a 5090 would be a good combo or newer cards later on
I must resist, my current card is only about 3 years old so I don’t NEED an upgrade.
Along with the 60 series(and AMD equivalent) waiting for the Zen 6, have the Asus B650E-E Gaming WiFi will that work with a bios update or will need to upgrade?
What do you have?
What do you have?
a bios update would be needed eventually for zen6 for now if its not broke don't fix it, my system is in the sig below the post
Not showing it on the iPhone, on iPad now and can see it. Why do you need a new 5090 if you already have one?
the fe's a good card but seeing the pro art, its something that very much interests me, same length, but a bigger cooler which will help with temps, i have someone lined up to take my fe if i can get the pro art card
Pre-ordered the new AOC AG276QSG2 Gsync Pulsar screen, haven't seen any info on how long it's likely to be on pre-order for though, is there any info about that? (General information suggests February sometime based on what i've seen, any confirmed dates though?)
rjk, do you know if you're getting any Razer Boomslang?
No updates on this yet. Razer dragging their heels with setup and availability on that line and a few others according to our peripherals PM.
Sorry we dont have anything concrete on that yet.
