- 25 May 2008
- North Wales
Are they worn evenly across the whole tyre or is it just an inner edge that goes first?
Sounds like you drive a lot harder than the average person and if you do then that's just the cost of doing business.
Also it's generally a good idea to rotate tyres so you don't end up with ones that are way older on the back than the front, best to rotate and the replace all 4 at once if you like to drive in a spirited fashion.
