Specing a New Gaming PC for my Friend - £1500ish
13 Dec 2006
Greetings, fellow computer enthusiasts,
As my post history will no doubt attest, I'm a longtime occasional lurker of these forums, and I pop out of the woodwork every few years when it's time to spec a new pc project, the better to avail myself of your tremendous collective knowledge and experience on all matters pc-related.
A friend has asked if I could help him build a new pc. He'll use it in his home office, to do his business accounts and so on, but also would like something that can, quote, "run Baldur's Gate III, Warhammer Total War, Cities Skylines and, eventually, Medieval Total War III." He's been out of the loop for a long time - he currently does his accounts on an 18 year old (!) laptop - so the upgrade is overdue, he's excited to get chance to get back into some gaming again, and I'd like to do the best job for him I can.
He is sorting out the monitor through someone else, and I've no idea on spec and resolution, so I can't say if we are targeting 1080p, 1440p or 4K - so i'll just try and cover as many bases as possible within budget.
I've explained to him about RAMpocalypse, etc, and he's aware, and resolved we shall just bite the bullet and go ahead. He hopes to get a decent few years of use out of this machine (maybe not 18 years between upgrades again, mind you).
Budget is £1500, though he says he could stretch if needed.
I've told him to budget £200 separately for a copy of Windows and a basic keyboard/house/headset. So I've left them out of the build budget for now.
To give him an idea of available options, I've provided him two specs. One is for the machine I'd do for £1500. The other is for the machine I'd "ideally" do if I was picking out bits for myself, as a gamer, without necessarily saying I had an unlimited budget and wanted to just have the most-expensive-everything. I am not pressuring him to go for the latter basket in its entirety, but I thought it would help him to see what upgrades to consider if he did want to stretch on any given aspect of the build.
I have specced Fractal Design cases because I like them, I usually use them for my own builds, and I trust to their build quality. They're also narrow enough, since he'd ideally like the machine to fit in a cubby-space that is 230mm wide (so max width of 220mm for the case, with clearance). I've explained and checked that we need adequate room for airflow at the front & back, ideally the top as well.
He's not fussed about water cooling AIOs or RGB lights, so I've stuck with air cooling.
Basket 1, targeting his £1500ish budget:
Total: £1,544.83
And my "bigger budget" machine:
Total: £2,251.84
About the latter, I've said to him that if he had another £200 to spare, the first thing I'd do would be to opt for the better CPU, primarily on the basis that CPU upgrades are marginally more of a faff, and it saves him thinking about it in the future (plus the 9800X3D is so well-rated). After that, if he can find another £200 again, to go for the 9070. The rest is "nice to have" stuff but not so impactful. I've caveated that by saying that if he does definitely want to game at 4K native right away, then maybe prioritise the 9070 first, and just accept the prospective hassle that he might want to upgrade the CPU one day (or, then again, might never find he feels it necessary).
I explained as well that, were it 4 months ago, I'd recommend C28 or C30 RAM, but with current availability and prices, a higher-latency kit with a reasonable speed may be the compromise we have to make to stay on any kind of budget.
Observations, alternatives, recommendations, mistakes, all welcome. Have I done anything egregiously foolish?
Thanks all!
£200 (incl. VAT)
£170 (incl. VAT)
£380 (incl. VAT)
£350 (incl. VAT)
£175 (incl. VAT)
£160 (incl. VAT)
£217 (incl. VAT)
£160 (incl. VAT)
FREE DELIVERY
£135 (incl. VAT)
£123 (incl. VAT)
£420 (incl. VAT)
£400 (incl. VAT)
£410 (incl. VAT)
£380 (incl. VAT)
Dump the pci-e 5 drive as it only looks good on benchmarks and will save £100 going to a sn710 but I would spec a 2TB drive as 1tb will fill up very quickly unless hes going to play one game and then delete that and install another one.
Also drop the noctua to a thermalrught peerless assassin 140 for £40 and use the £30 saved to upgrade the 9070 to the asus prime 9070XT.
My basket at OcUK:
Total: £1,209.88 (includes delivery: £0.00)​
9800x3d is happy with slower CAS ram so cas 36 is fine there.​
Good point - prices on the 9070 have gone up, and if you can get an XT for an extra £30 now, that is a better deal.
Agree I'd rather spec him 2TB if I can, and more space makes more sense than faster benchmarks.
Yeah I agree the £40 saved on the Assassin versus the Noctua is an easy win.
Thank you both, very helpful.
So if we were to look at a £2000 cart, we might say it'd look something like the below.
My basket at OcUK:
Total: £1,992.79
Then he has options. If he wants to save £200+ and can accept playing at 1080p for now, maybe upgrade later, just take a 9060XT instead of the 9070XT. And if he wants to save £100 and can accept installing one or two games at a time, with option to add extra storage in the future, go with the 1TB drive instead of 2. Neither is ideal, obviously, but I feel that's where the significant savings are to be found.
9060 XT can do 1440p reasonably as well (depends on games and expectations obviously), but it'll make a big difference to the overall gaming performance of the PC, so personally I'd cut almost everything else first, like the board (even B650 if need be), the CPU (e.g. 7800X3D), the case, PSU. Micro-ATX could be an option, though they tend to be wide cases nowadays.
If SSD prices follow RAM up the creek, that could be a costly oops.
The Fractal case only comes with 2 fans so you would ideally need at least 1 more.
These 3 changes will save nearly £100.
My basket at OcUK:
Total: £566.92 (includes delivery: £11.98)​
Case is good, i have it myself and the PSU only has a 8 year warranty. (so you could keep the 2TB drive)
M-ATX alternative that comes with plenty of fans included.
I wouldn't personally bother saving £35 on a 7800X3D over a 9800X3D, but I would seriously consider a six core X3D variant for £160 less:
My basket at OcUK:
Total: £1,758.80 (includes delivery: £11.98)​
If RGB isn't wanted you can just turn the lights off/not plug them in.
I wouldn't spend £100 on a Windows licence either, OEM licences can be had dirt cheap and will work fine.
Really appreciate the help, everyone. I had a feeling there'd be options for saving some pennies in various places, and things I'd not thought of.
The point about SSD prices creeping up, and wanting to get that 2TB locked in now, is a particularly good shout.
All those smaller individual savings are definitely adding up, which I am sure my friend will appreciate. I feel a lot closer to a final kit list now.
This is also a very good case (built in one myself for a friend) with no rgb but you would need the 3 extra fans as it only comes with 1 included still saving £60 over the fractal case you specced.
The psu has a ten year warranty if thats important and is very quiet in all use according to reviews.
My basket at OcUK:
Total: £182.92 (includes delivery: £0.00)​
EDIT Unfortunately the case is 230mm wide so no good :(
Excellent, definitely some savings to be made on the PSU options. I'm not one for skimping on PSUs, but these are all well-reviewed, excellent suggestions.
I am coming a cropper with the cases choices slightly because of that 220mm width limit. Seems like the standard these days has been for cases to get a bit fatter, 230mm or 235mm, even in m-ATX, which won't have the clearance for the space where he wants it to go. It's been useful to sift the options, though, and maybe I can suggest to him that he could put the pc in a different location if it's going to save him £60 towards his graphics card! :cry:
Think that would be too wide, unfortunately.
Lian Li A3 variants maybe? Might need to reshuffle one or two components for it, plenty of visual variants of it and it's only 194mm wide.
My basket at OcUK:
Total: £289.82 (includes delivery: £19.99)​
Okay, so I am thinking we could suggest something like:
My basket at OcUK:
Total: £1,872.88
Plus a couple of fans.
(And with due acknowledgement to the couple of other case options that people have now kindly suggested - so my friend can pick which he prefers).
Looks like the price on that 9070XT might shift even as we speak, so I might need to lock that in!
Thanks again, everyone. I am very grateful for your characteristically helpful, knowledgeable and rapid responses. It really is appreciated. I will keep you updated.
