OcUK HAS THE LOWEST PRICE ON CL30 6000MHz 32GB MEMORY KITS !!!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As an introductory offer as were now working directly with SK-Hynix with their retail brand Klevv, we have an introductory offer on this FIT V 6000MHz C30 kit which should be lowest price in UK for a C30 6000MHz 32Gb kit. :)
  • SKU: MEM-KLV-07036
  • EAN: 4895194968795
  • MPN: KD5AGU880-60A300L
KD5AGU880-60A300L, 6000MHz RAM Speed, CAS 30-36-36-76 Timings, 1.4v UDIMM.
£380 (incl. VAT)
£350 (incl. VAT)
KLEVV FIT V 32GB (2x16GB) 6000MHz CL30 DDR5 Dual Channel Kit - Black​
KD5AGU880-60A300L, 6000MHz RAM Speed, CAS 30-36-36-76 Timings, 1.35-1.4v UDIMM.
- Ultra low-profile for excellent compatibility with larger components
- Carefully selected superior quality ICs, without mixing memory IDM, to guarantee unparalleled performance and reliability
- Intel® XMP 3.0 & AMD EXPOProfilesOne-click overclocking unleashes the full performance of DDR5
- On-die ECC and PMIC for long-term data reliability, stability, and efficient power supply
Experience seamless multitasking and graphics rendering with the FIT V, equipped with high frequencies of up to 6400MT/s. Enjoy low latencies for faster response times and smoother and stable system performance that can easily keep up with your demanding workload. The FIT V boasts a sleek and minimalist design with excellent heat dissipation at only 33.2 mm in height. The low-profile aluminum heat spreader ensures extensive compatibility for diversified configurations, providing users with more flexibility when selecting components for their PC build. At KLEVV, we understand that choosing the right memory can sometimes be challenging. That’s why we’ve designed our products for broad platform compatibility—making it easier for users to find the ideal match for their system. FIT V is optimized for AMD platforms, while maintaining compatibility with legacy Intel platforms. Check the table to ensure optimal compatibility with your respective platform. Maximize performance with pre-programmed FIT V settings for optimized timings, voltages, and speeds through both Intel® XMP 3.0 and AMD EXPO™ on-board profiles. KLEVV is a premium memory brand known for our expertise in delivering high-quality DRAM products, where our memory modules are crafted with exceptional attention to detail and the finest components, setting the standard for reliability and quality. The FIT V has undergone thorough testing for the world's renowned leading motherboard manufacturers' Qualified Vendors List. Our memory is designed to deliver impressive performance and compatibility with all major motherboards on the market.
Fit V the perfect match for a 9850X3D, 9800X3D and 9950X3D processors!
BUY NOW ONLY £329.99!
Most competitors both in resellers and other memory brands are average around £100 more for such a specification of kit, hell this is even cheaper than the budget 4800-5200MHz 32Gb DDR5 kits, making it the best deal out there in current climate.
OcUK is massively expanding its memory range, more KLEVV in coming and other brands such as Adata, Biwin, V-Color are all incoming which makes OcUK the no.1 place for DDR5 memory needs, we are also still stock a large range of DDR4 as well. :)
Crying at just buying my daughter a new budget DDR4 rig rather than upgrading mine to AM5 because all the Ram was so expensive!
It's insane the amount they have gone up for and to make it worse people are still buying them.
I've had a few friends put off upgrades due to the prices. Feel sorry for the people that have to buy the ram as even if I had too I would not be paying current prices.
That Klevv memory is very good but the prices everywhere are just ridiculous now. I paid just £89 for my 32Gb Klevv Bolt 6000mhz C30 last year!! Bloody AI!!
OcUK cannot change world forces and pricing globally.
What we can do is try to bring consumers the best deals in current climate, which correct me if I am wrong but nowhere else has a cheaper CL30 6000MHZ EXPO/XMP 32G kit in stock available. :)
Yeah wasn't aimed at ocuk and it's the manufactures at blame but let's call it for what it is - price gouging. But manufacturers will continually try to get way with it if people continue to pay the ridiculous prices.
You can see where this is all heading where the average consumer is priced out of owning anything and we'll then have the luxury of a subscription style model where we have to rent computing power.
yer i'm sure they are fine, modules are not the most complicated things, they prob use there own stock reference PCB
The memory is very tweakable. I have only played around with the timings which made a big difference in Aida64 but they are also supposed to be very overclockable too. I could probably go further with the timings but that took ages and I just can't be bothered spending hours tweaking and stability testing these days.
The top image is the stock timings and the lower image is my tweaked timings. Keep in mind my kit is the Klevv Bolt set and not what OCUK is selling although I am sure similar results could be had as their kits always tweak well in reviews.
Yes same IC as Bolt, difference is heat spreader.
We do have full range of Klevv incoming including Bolt and Urban, but the Fit V is the lowest price, so much so I took 5000 of them. :)
Sorry to take thread slightly off topic, but I always thought GDM should be off? Although your timings look to be of even values, so probably not a big deal. Just that GDM might make something appear stable that isn't and also it isn't technically running at 1T.
Yep, it's gone so bad that some commercial brands are not taking on new enterprise customers this year due to the uncertainty in spot bid pricing.
What is GDM? I just left everything eelse on auto.
