Hi there
As an introductory offer as were now working directly with SK-Hynix with their retail brand Klevv, we have an introductory offer on this FIT V 6000MHz C30 kit which should be lowest price in UK for a C30 6000MHz 32Gb kit.
KD5AGU880-60A300L, 6000MHz RAM Speed, CAS 30-36-36-76 Timings, 1.35-1.4v UDIMM.
- Ultra low-profile for excellent compatibility with larger components
- Carefully selected superior quality ICs, without mixing memory IDM, to guarantee unparalleled performance and reliability
- Intel® XMP 3.0 & AMD EXPO™ ProfilesOne-click overclocking unleashes the full performance of DDR5
- On-die ECC and PMIC for long-term data reliability, stability, and efficient power supply
Experience seamless multitasking and graphics rendering with the FIT V, equipped with high frequencies of up to 6400MT/s. Enjoy low latencies for faster response times and smoother and stable system performance that can easily keep up with your demanding workload. The FIT V boasts a sleek and minimalist design with excellent heat dissipation at only 33.2 mm in height. The low-profile aluminum heat spreader ensures extensive compatibility for diversified configurations, providing users with more flexibility when selecting components for their PC build. At KLEVV, we understand that choosing the right memory can sometimes be challenging. That’s why we’ve designed our products for broad platform compatibility—making it easier for users to find the ideal match for their system. FIT V is optimized for AMD platforms, while maintaining compatibility with legacy Intel platforms. Check the table to ensure optimal compatibility with your respective platform. Maximize performance with pre-programmed FIT V settings for optimized timings, voltages, and speeds through both Intel® XMP 3.0 and AMD EXPO™ on-board profiles. KLEVV is a premium memory brand known for our expertise in delivering high-quality DRAM products, where our memory modules are crafted with exceptional attention to detail and the finest components, setting the standard for reliability and quality. The FIT V has undergone thorough testing for the world's renowned leading motherboard manufacturers' Qualified Vendors List. Our memory is designed to deliver impressive performance and compatibility with all major motherboards on the market.
Fit V the perfect match for a 9850X3D, 9800X3D and 9950X3D processors!
BUY NOW ONLY £329.99!
Most competitors both in resellers and other memory brands are average around £100 more for such a specification of kit, hell this is even cheaper than the budget 4800-5200MHz 32Gb DDR5 kits, making it the best deal out there in current climate.
OcUK is massively expanding its memory range, more KLEVV in coming and other brands such as Adata, Biwin, V-Color are all incoming which makes OcUK the no.1 place for DDR5 memory needs, we are also still stock a large range of DDR4 as well.
SAVE 5%
- SKU: MEM-KLV-07036
- EAN: 4895194968795
- MPN: KD5AGU880-60A300L
KD5AGU880-60A300L, 6000MHz RAM Speed, CAS 30-36-36-76 Timings, 1.4v UDIMM.
KLEVV FIT V 32GB (2x16GB) 6000MHz CL30 DDR5 Dual Channel Kit - Black
