Slimed down fresh install of W11?
19 Oct 2004
London
I've just swapped over to a 9070xt from a RTX3080 and it's working fine, but it's made me look at the amount of **** on my computer and the amount of random stuff I've installed over the years, and it's made me think a fresh install might be a good idea.
I mainly play games on my PC - I have a mac for video editing - so am looking for a v.slim install - debloated, though not to the point stuff is going to stop working. Now when I open task manager there are about a million processes doing they're thing and I'd like that to stop. Are there any video guides people would recommend or ISO builds people trust?
Thanks
Dave
I'm running this as a secondary boot option on my laptop and it's great, just built an image using the latest ISO from MS. The Windows side of my laptop is used purely for software to interface with things and stuff (car diags etc) so it doesn't need all the guff and this fits the bill nicely.
I use the image with Ventoy, then on the Ventoy drive I have a files folder with installers for Firefox, etc. as you get no browser on a tiny11 build. Slap any drivers you might need, or any other software and you're away. Going to rebuild my Battlefield 6 partition on my main PC with it later this year.
"Not to the point Where stuff is going to
Stop working "
That's always the issue when
Slimming down windows
You may remove something that something else
Has dependancies on
And you dont find out
Until you go to do something and
It won't work
Theres tools like Chris Titus utility
I used that
Then used rufus afterwards to bypass
All the Microsoft make an online account blah blah
Ended up with a nice iso that had very little
Background processes and ####
Though I have multiple drives with different windows installed
On them
I wouldn't risk a modified/slimmed windows
As my only OS
And yeah ventoy is great
Just throw all your isos on there
It will even put ventoy on fixed disks too
So I have a m2 with ventoy and all my isos on it
Faster than me hunting for the right USB flash drive
And loads faster too
Can use something like ninite too
Or winget
To automatically install browsers etc after installed windows
I used to use the MSMGG toolkit to make my own ISOs but the developer has not been around for over a year and its not been updated in some time which is a shame.
Could always give NTLite a go. Remove features you don't need, add updates/drivers and configure your Windows installation.
Last time I checked this some features where locked behind a paywall as the free version does not do everything (Which is fair enough)
May want to change your thread title @BS Dave , I'm presuming you're not after a 'slimed' down fresh install or is that a Freudian slip?
What video did you follow or did you use his tool to create the Windows ISO?
I think its this one
He sells an easy to use .exe but also does it free, if you watch the guide and use the github link in the comments.
I have a solid repo here for the which I use for the ASUS XBAX. You can tweak the apps, buts it's far more succinct than Chris Ts "live" version. The only way you can truly remove Windows bloat is by modifying the WIM, or doing it during WinPE/OOBE (which is what my script does).
Provides full logging to event viewer and outputs a text file too. Just follow the readme, but also feel free to ask if you have any questions.
As an aside, this will work well with for any PC, but particularly gaming rigs where I see on average 20 to 40 FPS up over a vanilla W11 build.
