HAVN - Element
22 May 2010
Minibotpc
Finished with one and onto another!
I've teamed up with HAVN to do a build in their new BF360! We have a new sponsor for this build too, SAPPHIRE Technology is sponsoring the core components!
Huge thanks to them for providing us with their B850A WIFI7 PURE Motherboard and 9070 XT PURE Graphics Card. A beautiful pairing for this black and white themed build.
Core Component list:
HAVN BF360 Flow Edition
AMD 9800X3D
Sapphire B850A WIFI7 PURE Motherboard
Sapphire 9070 XT Pure Graphics Card
Anaconda G5 Python 32gb DDR5 Memory Kit
Anaconda i4S Gen4 1TB NVME SSD - ANA Edition
FSP VITA GM 750W Power Supply
Cooling - Air
Noctua NH-D15 G2 Chromax Edition
Noctua NF-A14x25 G2 Chromax Edition
HAVN Universal Vertical GPU Mount with Riser Cable
Cooling - Water
Bitspower - Fittings TBC
Bitspower - Prime Waterblock
Bitspower - Leviathan II Radiators
https://i.~ibb.co~/V0JDjP18/MBP03405-Enhanced-NR.jpg https://i.~ibb.co~/pvdJd70K/MBP03407-Enhanced-NR.jpg
https://i.~ibb.co~/CKMPRyLL/MBP03412-Enhanced-NR.jpg https://i.~ibb.co~/bRH5jFKJ/MBP03406-Enhanced-NR.jpg
https://i.~ibb.co~/s9kPkT3y/MBP03409-Enhanced-NR.jpg
A couple more updates on the project.
Not so much update but product shots!
https://i.~ibb.co~/SwfkFbcm/MBP03415-Enhanced-NR.jpg https://i.~ibb.co~/mrHFtmBF/MBP03416-Enhanced-NR.jpg
https://i.~ibb.co~/1JXzg8Md/MBP03417-Enhanced-NR.jpg https://i.~ibb.co~/N2306Fp2/MBP03418-Enhanced-NR.jpg
https://i.~ibb.co~/HTmxPjzV/MBP03420-Enhanced-NR.jpg https://i.~ibb.co~/xv7kHG3/MBP03421-Enhanced-NR.jpg
https://i.~ibb.co~/vx42Gphm/MBP03423-Enhanced-NR.jpg https://i.~ibb.co~/gpkZzm4/MBP03424-Enhanced-NR.jpg
https://i.~ibb.co~/twC34Sr4/MBP03425-Enhanced-NR.jpg
https://i.~ibb.co~/20VXzhsr/MBP03428-Enhanced-NR.jpg
https://i.~ibb.co~/NgWpW6xf/MBP03432-Enhanced-NR.jpg https://i.~ibb.co~/Lzv1rcYZ/MBP03434-Enhanced-NR.jpg
Anaconda M.2 (and Vita PSU): Well, nobody can accuse you of boringly using the same components as every other build! :D
The front of that case looks like a rad already. Can't tell from their pics, probably not deep enough but it almost looks like they could have designed that front to swallow a 360 without trace.
A 420 or 360 can fit in the front. It comes with 2x180 fan installed
The manual says can take 3x120, 3x140 and 2x180 fans in the front, and it can support 360 and 420 rads in the front
Just checked their website as well, the non-Flow version does, but the flow version says it's just 2x180 (seems to be the main difference apart from the bundled fans)
Or do you have the flow?
Sorry my mistake, yes you are correct. The Flow doesn't include the bracket for the 120mm or 140mm fans.
Fkn love Havn cases, alt version of their HS420 VGPU
(If I had 420 for the bottom, I would have)
Is that finished? Can't see a tube running from one side of the CPU or bottom rad?
Also... hope your sig is out of date - putting that much effort into an FX8350 build at this point would seem a bit mis-guided :P
Nah, I messed the last tube up and bodged it for now.
Very out of date, that's the last time I came on here tbf....
