Thank you Jonny! This is reassuring! I will experiment with your suggestions!The recipe looks fine. You don’t need the sugar or olive oil and I’d probably add another half teaspoon of salt for taste, but the recipe doesn’t look like the cause.
Knead it for longer in the mixer. Doesn’t matter what the instructions say, 2 minutes definitely isn’t long enough and a longer knead is always beneficial. Do 7-8 minutes minimum, preferably 10.
First rise for an hour sounds fine. Depends how warm your kitchen is. The longer you leave it at this point, the better the loaf tastes and the more active the yeast gets.
You can re-knead it in the mixer, but it would be better to scrape the dough out at this point and shape it into a loaf. Then, depending how warm your kitchen is, you need to leave it to pop back up for 30 mins or so before baking. Oven needs to be 230°C ie HOT.
Baking in a tin will restrict the loaf popping up and will always result in a more dense loaf than open baking. I’d recommend baking on a pizza tin or something. It’s also a LOT easier to get a smaller loaf to pop up and be fluffy, so consider practicing with a 300g flour recipe. Same flour:water ratios as 500g:
300g flour
200g warm water
1tsp salt
1tsp dried yeast
My top tip to stop it sticking during baking: bake on non-stick greaseproof baking paper!
Thank you, I will report back.If I had a probe thermometer I would now be putting that to the test ... or, equally performing the window-pane test that many of the online videos do.It doesn’t raise it very much, in my experience. Dough hooks, Kenwood Chef stand mixer and Kitchenaid Artisan.
www.kannammacooks.com
I find the rise is more tied to good gluten development and accurate timings for proving, rather than flour type (experimented a lot in my early baking days). I did up my starter (levain) quantity from what initial recipes used to say, and have refined to the above quantities baking twice weekly with this bigger loaf-tin for over a year now.Never been able to make it last that long.another couple of days towards the 7-8 day mark
suggests it's wholewheat, but that looks white, and says rising might be lower dued to milling strategy ..
but on the other hand looks like a cheapish flour I'd never considered.
looks good , as does Rays - Briochee with eggs, even washed ?
I need to re-evaluate cheaping out with non-enhanced douighs.
I subsequently watched this video on dough improvers
and am looking at this product, in my next amazon S&S
Organic Flour/Bread Improver | Whole Food Earth®
If you enjoy making homemade bread, this flour improver is designed to help enhance the quality of your loaves - fluffier, lighter with better texture a...wholefoodearth.com
strangely the packet doesn't seem to say recommended dose
