Removing so much Paint
27 Mar 2016
Bristolian living in Swindon
Hi all
We moved into my wife's childhood home a couple of months back and we're in the process of decorating room by room, we're getting a new bathroom fitted within the next 2 or 3 weeks but want to get paint of the walls...
Basically the issue is, her dad painted on top of paint about 3 or 4 times and it's gonna be a pain to get of I imagine, Does anyone have any tips as to making it easier to remove please?
Thanks
Heat gun and scraper.
I would have suggested Nitro Mors, but with the nerfed formula they use these days you'd be better off with something stronger like your creepy uncle's Brut aftershave.
I'll see if I can get a heat gun from someone, need to get it stripped pretty soon
Not sure I’d remove the paint to be honest. Probably just sand it to key the surface then prep and paint away. Full paint removal sounds like more trouble than it’s worth… unless of course you need to remove the base coats because they are failing to adhere or something
Would this be a case of sanding the whole room? We removed the cabinet he had on the wall and it's revealed, two layers of blue (different shades) and the current colour on top
As above - unless the walls are really poor, I’d honestly just key them, level off the bit that needs levelled, then paint away. No real reason why you can’t paint continually on top, unless the paint below is losing its adherence to the wall, or there is an incompatibility between paint finishes… usually the latter can be resolved with a suitable primer / prep.
If using a heat gun in a carpeted room make sure you protect the floor.. I found that to my peril when I decided to strip the paint on the door frames in our new-to-us house several years ago. New carpet nicely singed in so many rooms. Yes, I'm a slow learner.... :/
This
"I would either SBR bond then skim it with multifinish, or if walls not flat remove plaster back to brick and board. If you want to do it properly anyway.
Not many situations I'd be removing paint from a wall unless painted wallpaper."
Hi all
Thanks
Isn't it generally accepted that you just paint over paint?
What are you going to do with the walls if/when you strip the paint off ? If its papering or tiling, just do that on the existing walls. Or is it a case that the walls were striped in pieces previously and it's now badly uneven and you are painting on a wall that has various levels of old paint?
If it's uneven paint, I've seen lining paper used to get back to an even surface, and then paint on that.
