Wired Earbuds
25 Jul 2009
England
Hey,
my Jaybird Vista 2 wireless earbuds seem to have failed (sync button no longer works). Recently got a new phone and the sync button will not work. Tried factory resetting/following video tutorials.
I'm looking at going back to cabled/3.5mm jack earbuds.
Can anyone recommend some please? Would like some with good bass. Mainly listen to rock/90s rap.
Ideally below £30/£35. Only use for morning dog walks.
Many thanks in advance.
I got some House of Marley USB-C recently after getting fed up of Bluetooth headphones randomly dropping out with my Poco phone
For a tenner I wasn't expecting much but have been pleasantly surprised
Are you looking for ones which go in the ear canal or flatheads? I'm assuming wanting something of similar style to the Jaybird Vista.
Personally a fan of Fiio currently, though availability is a bit mixed, some decent priced offerings with reasonable build quality and engaging audio presentation / quality.
Another option which is quite popular is the Linsoul / Truthear Crinacle range though build quality is a bit mixed.
Yes, more in the ear fitting.
Will take a look, cheers :)
Just having a look, the availability of the ones in you budget from Fiio looks pretty poor currently - haven't check AliExpress but their usual UK sources only seem to have the LOL money ones aside from the JD1.
