Case swap pooped PC
10 Apr 2015
Hungerford, UK, Earth
So i bought a jonsbo case in the case sale. swapped out everything, and now pc dead . nothing works.. ive checked all cables removed everything nothing. dead as a dodo. when i plug the power cable in i dont dont get the normal little crackle. its uses a pass through cabled, ive bypassed that and used a different power cable.. I can only come to the conclusion the PSU has died which isnt that old (Antec SF850X 850).. Im at work at moment, but the only thing left is to try another PSU i do have fractal gold rated 550w spare.
PC is ryzen 5800x with a Asrock B570 GPU and an asus tuf gaming a520 motherboard.. so annoying should have been such an easy task :(
i
Most basic of tests: Unplug everything from the PSU and bridge the green cable on the 24pin with any black - PSU should spin up.
Are you sure the power button on the case actually works? Tried jumping the pins on the motherboard? They're labelled, not colour-coded ;)
Are you using the board risers to keep the motherboard off the chassis? Saying that, if it's blown the board it could be too late to worry about it.
99% sure i checked all the standoffs, i will find out when i remove the mobo. havnt got around to it yet
pc stripped down, and working. the motherboard cable on the psu side had worked lose (which i coulldnt get to in the case).. all working brown trouser moment over
Pebcak strikes! :P
At least it was not an expensive disaster.
The D31 is a nice case...I use it for my main rig as well
