Advice on battery replacement
14 Jan 2004
Reading, UK
Hi folks,
I have a 2014 Honda Civic 1.8L with a start-stop engine, reg WJ14 KPG, VIN SHHFK2760DU006548. I need a replacement starter battery, but I'm getting conflicting info basically everywhere I turn - various part shops, AI agents, even the mechanic I usually use. Some are saying I need an AGM battery like the Yuasa YBX9028, some are saying an EFB like the YBX7072. Some say I could use either, and that an AGM is just an upgraded version of the EFB, some are saying it must be EFB for my start-stop. The car was purchased second-hand with a 7072 battery (not the OEM part), the start-stop worked for a while but hasn't in a long time.
This is driving me nuts! Could anyone assist, please?
Call your local Honda dealer parts dept and see what they offer when you give them the details.
I tried this first, they only give me the info that it's an "L2" battery, which I think refers to size rather than anything else.
My Volvo has stop start so AGM battery.
After a lot of digging the cheapest place to get any sort of reputable battery, was actually from Volvo themselves for the Volvo branded battery.
That is usually the last place I would look.
Worth calling your local Honda dealer you never know....
Volvo assist just replaced my main 95Ah 850CCA battery, £300 fitted for a genuine Volvo part including resetting the BMS, this was only £80 more than Halfords and that was for the parts only.
So ask Honda.
Thanks all, I've asked Honda direct and they want nearly twice what it would cost for me to buy the part and have my usual mechanic fit it.
Interestingly, Varta list the AGM as an upgrade over the EFB, but Yuasa (who I think are actually the OE which Honda uses) only lists the EFB as suitable when I give them my reg.
AGM is listed for electrical heavy cars with more loads, or cars which which are expected to do loads more stop start trips.
EFB will be fine, just make sure you get the right Ah and CCA.
AGM will likely be undercharged if your cars charging system is optimised for EFB.
Have you tried Tayna batteries website? They are usually well priced and will recommend based on reg. I recently fitted an AGM for my Mondeo and it has been good. Bought it from Tayna, can't fault their service.
Also, check whether your current one is Standard, EFB or AGM. I learned that you can only go one way or stay at same level. I cannot downgrade to an EFB in the future for example.
I've tried a few lookups by reg, including Tayna! The thing which is giving me pause is that some recommend EFB only, and others (admittedly more) recommend either - indicating that an AGM is a viable upgrade from my current EFB.
I've since spoken to someone at batterycharged.co.uk who very kindly talked me through it and was very sure the AGM is the better option. I expect he knows what he's talking about, so that's good enough for me. My current battery is an EFB, it's a few years old now but the start-stop stopped working pretty early, so maybe that's an important bit of evidence.
Interestingly, he specifically called out AI for providing bad information (and I did use it as part of my research on this subject).
Thanks everyone for your input !
