During my testing, the installs were fresh on virtual machines.How do you mean? Forgetting folder views (regardless of what folder) is a typical Windows issue that has been around since XP. Deleting manually Bags and BagsMRU from the registry resolves it until the folders congest again down the line.
Yeah, I've found the same, the download folder and the folders inside the download folder always seem to revert to grouped, but I have other folders elsewhere regularly do that as well and then switch back later (even though I changed nothing).During my testing, the installs were fresh on virtual machines.
As an example, download an archive, extract it, then navigate to the newly created folder and only to find Windows has set the view to grouped. Change the view so the files are ungrouped, close the explorer window, navigate back to the same folder and I almost always find my changed group setting undone and the folder is grouped again. The same applies for the download folder itself, Windows always changes the view to grouped.
I've encountered Windows forgetting folder views on older Windows installations, especially when a lot of folders have been viewed.
Handy if you have a spare drive sitting around doing nothing.going to iot ltsc a go, doubt make much of a difference but its 90 day free so y not
www.dell.com
Microsoft confirms Windows 11 has been downgrading graphics drivers, reveals when a fix is coming
Microsoft has quietly confirmed that Windows Update has been downgrading user-installed graphics drivers, but it's being fixed.www.windowslatest.com
