Vans - talk to me!
6 Oct 2004
Birmingham
I'm pondering what to do when the lease on my e-Niro finishes in ~10 months (yes I know it's a while, but the reason I'm looking now is below)
While it's a great car, and ticks almost all the boxes, it does let us down somewhat when going on family camping trips. Since the other half decided to get a dog - a very big dog who takes up 90% of the boot - loading up the car is a bit of a game of tetris, with bags piled up around the kids, a roofbag stuffed almost to bursting with sleeping bags etc., and a lot of "sorry, can't take that, not enough space". This is frustrating but bearable when packing at home, but when you're packing up a wet and muddy tent that weighs 40kg dry in the rain... yeah, not fun at all; we've only been camping once since getting the dog :(
That leaves me thinking it would be great to have a (4+ seat) van; not only for camping trips but also if we fancy taking the bikes out somewhere (saves having to put a bike rack on the car) for tip runs, etc.
The reason for looking now is that we have a family camping trip arranged in July, and would be nice to have something in place by then if it fits the requirements.
I've narrowed our options down to 4 choices:
1. Replace with an EV van, e.g. an ID.Buzz or PV5.
My preferred option in terms of simplicity and "nice" vehicle, however also the most expensive. the cheapest Buzz on AT is £30k - that's 3 years old with 74k miles. The PV5 has only just come out, and while I expect prices to drop, it's probably going to be a couple of years still before they're within my preferred budget.
2. Replace with a mid-range ICE van
Not ideal, while initial purchase price would be relatively low* (obviously depending on what I get), running costs would be significantly higher than my current car, and lots of short journeys aren't going to do it any favours!
3. Keep the e-Niro (if I'm able to buy it at the end of the lease, if not then replace with similar EV), and buy an older ICE van to run alongside.
Best option in terms of flexibility and vehicle suitability; keep the EV for day-to-day use, with the van being used occasionally for the camping trips etc. Price difference in fuel vs public rapid charging is negligible, so not much extra cost there, especially when considering the savings in eVED vs using an EV. Does however mean paying double insurance and double VED, although could consider SORNing over winter when we're unlikely to use it.
4. Keep the e-Niro and carry on making do without, or hire/borrow a van when/if needed.
While this would be the lowest overall cost, it's not a great option to be honest - doesn't solve the problem, and hiring a suitable van for a week is close to £1k, very quickly wiping out any savings vs the other options.
So TL;DR; looking at van options to either replace or run alongside a cheap EV (as mentioned above, my preferred option would be an EV van, but due to current pricing I'll disregard those for now)
The main options I've looked at so far:
  • VW transporter/kombi/shuttle/caravelle/etc. - The classic; plenty of these around, owners forums, parts availability etc. all seems great, but the scene tax is insane. Are they really significantly better than the other options, or is it just a case of being part of the "VW Club"?
  • Hyundai i800 - this seems to be a bit of a hidden gem really. Plenty of space, a bit more "car-like" than some of the others, relatively cheap, from what I've found seems to be quite reliable. Too many seats, but looks easy enough to remove the 3rd row - problem then being storing them somewhere.
  • Honda Stepwagon - slightly more expensive than the Hyundai, and due to being an import insurance may be a bit higher, but what I really like about it is the 3rd row "magic seats" which fold completely flat into the floor. The vast majority of time we'd only need the 4 seats, so this would be really handy, rather than having to store them somewhere.
There are the obvious other options, e.g. the Vauxhall Vivaro and other Stellantis equivalents (which seem a bit cheap and cheerful) or Ford Transit (custom? or is it the Tourneo?), but they all seem to be a bit of a muchness to me to be honest.
Would really appreciate some thoughts, owners' experiences, suggestions of alternatives etc.
Edit: In terms of budget, if it was replacing the EV completely then let's say ~£15k, to run alongside then ~£7-8k
Edit 2: I have plenty of tools etc. and not afraid to get my hands dirty, so would be able to do a reasonable amount of maintenance/repairs on an older ICE myself. I can't weld though, and certainly wouldn't be confident in something like a full engine rebuild! :p
I'm wanting to do similar, got an Ioniq EV currently but really really miss having a van. I used to have access to a van from work and it was soooo handy.
The PV5 is top of my list but like yourself i'm usually spending sub 15k on a vehicle so it'll be a while until they get down there, otherwise that's the perfect vehicle for me pretty much.
While i don't know anything about transporters i did have a 16 plate pretty well spec'd VW Caddy as a work van for about 7 years, i thought it was tosh compared to the Nissan NV200 i had before, no idea what people see in the Caddy's and why they have the scene tax they command, they're just objectively not a very good van, not very nice to drive, engine was horrible, load space was naff compared to the Nissan and the screen for the sat nav/radio was way too low in the dashboard, weird sharp bit of dash right by the gearstick so you skin your knuckles if you don't pay attention changing gear etc etc etc.
I've looked at the Stelantis vans but they just seem pretty bad, very very inefficient, hear stories about averaging 2 mi/kwh in them being pretty standard so even with the 75kwh pack you've still got rubbish range.
I immediately wrote off the Stellantis vans after seeing the range, absolute best case scenario of 150 miles on the motorway just makes them completely unsuitable - which is a shame as something like a Vivaro would be ideal otherwise.
Interesting to hear about the VW being a bit rubbish considering the price premium, e.g. £10k will get you a 10 year old ~60k miles but relatively tidy looking Vivaro, change that to a Transporter and that £10k will get you something 15 years old with at least double the mileage; as "cool" as they are, that's a lot of money to pay for a badge!
Definitely tempting to just pick up a cheap i800 (or silly Jap wagon :D), even if only for a couple of years until the PV5 comes down
Just a word of warning, when looking at vehicles be very careful to check weather something is registered as a Car, Van or CamperVan. Since this will not only effect your insurance (some insurers get a bit funny about doing none business policies for Vans), but also vans are often subject to lower speed limits. Also some cities (eg Bath) have clean air zone charges for commerical vehciles, but not cars.
I'm also looking at this.
I am concerned with the increased anti van approach to car parks (fewer and fewer over night places) and height restrictions.
In Europe, yes, I'd already have done it. But the UK is getting very anti van. I do understand. There are people who ruin it for everyone. Particularly leaving litter. But the rise of van life is causing issues.
Yeah, something I think which needs revisiting as it has become increasingly complicated with newer vehicles and there are so many non-commercial vehicles now which are worse for the things like high centre of gravity than many vans which are limited, etc. and/or not much in it weight wise, etc. etc.
Good to know that you’ve written off the Stellantis vans. The Vivaro and related are absolutely atrocious vans. DPF issues are guaranteed. Absolutely the worst vehicles I’ve ever owned.
This may be a bit big for you going by what you’re looking at but check out the VW Crafter or the MAN equivalent. I bought a Crafter a few months ago and it’s a wonderful van to drive. It’s so good that I ended up selling my BMW cause I didn’t think it drove as well! VW vans always have a price premium because they’re highly regarded.
Thanks, I assume the standard UK ones like the i800 etc. will be registered as cars, but definitely something to look out for on the imports or anything modified. I'll make sure to check anyway :)
Is this not more to do with campers? Essentially what we want is just a "car" with a ridiculously huge boot
My brother has a Crafter which he's converted to a camper, it's nice, but definitely too big for us!
Can't tow with the Niro, and don't really have anywhere secure to keep a trailer.
Certainly an option to look into if we were to get a different EV which could tow though. There's space on the drive, and I'd probably need to sink an eyelet into a lump of concrete or something to bolt it to, but still would work out cheaper than a separate vehicle, and less compromise.
Roofbox ? Or a Nissan Elgrand - I miss mine !
I've got a big roof bag, even with that it's a struggle to fit everything in!
Elgrand is one I've been looking at, or similar, e.g. Alphard/Vellfire - what are they like on cargo space when compared to a more conventional van though?
Not sure on the newer ones, but the old E51 was pretty cavernous - even with the rear row of seats in normal position.
Yeah a trailer and EV is also an option i'm looking at, depends how often you need the extra space and if it's on long journeys as i can imagine charging up with a trailer will be quite a faff as so few in the UK are pull through bays.
The extra space is only really going to be needed on long journeys, e.g. when headed into Wales or Cornwall with the car loaded up with camping gear.
Thinking about where we usually stop to charge en-route, you're right - it would be entirely unsuitable for having a trailer connected :(
..but as has been pictured by jonny in the past some charging stations have pull through slots for caravan/trailers (which ev's have nose charging too)
Have you looked at Toyota Alphard.
They are an import, but in my experience imports havnt been too bad to insure
Another one for The Alphard, although I may be a little biased as I own one. By my golden retriever loves it. Only down side is they can be a little have on fuel depending on model. Other honorable mention is the toyota noah/voxy.
i800s should be fine, it's more Transit Customs, Transports and the 50 billion Vivaro clones where you might have an issue.
I'm now definitely considering one of these... £8-10k seems to get a half decent example.
Stuck all the figures in a spreadsheet, and while it's significantly cheaper to just run an EV, I'd have to be doing at least double my current mileage in an EV for it to make financial sense to have both - the double insurance/VED/servicing/maintenance etc. wipes out any possible fuel savings, even at the current prices!
So I guess... do without or ICE van only - in which case it makes sense to go for something a bit more "car like" than a passenger van...
Shame there isn't a phev version of something like the Alphard that would be perfect - there's a hybrid, but it seems like there's not actually much in it in terms of MPG?
