So try running a game in window mode on the deskto leave it there and see if what happens? What low level 3d game/ app would you suggest, something like Candy Crush?Not necessarily, but if C-State is off and no curve optimiser then it is unlikely the CPU idle states.
Personally, if this remains true, that it only reboots with the LG C9, then I'd suspect either: the card's handling of power states. An issue with the grounding of the monitor, like the cable, or a surge protector.
The former can be tested by running something else (3D) in the background to hold the power state, like a low-demand game, the latter can sometimes be mitigated by using an adapter e.g. HDMI to DP.
