Advice for this build?
26 Nov 2017
AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor
Thermalright Aqua Elite V3 66.17 CFM Liquid CPU Cooler
Gigabyte B550 EAGLE WIFI6 ATX AM4 Motherboard
Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
ASRock Challenger Radeon RX 9070 XT 16 GB Video Card
Deepcool CG530 ATX Mid Tower Case
SeaSonic Core BC 750 W 80+ Bronze Certified ATX 3.1 Power Supply
I want it for 1440p gaming, new games, no heavy RT
Yeah give a bit more info from the template if you want any comments.
It's a capable machine on the face of it, AiO is probably overkill. CPU could be changed depending on usage and budget.
thanks. I managed to find quite cheap aio, thats why I chose it.
Can you put the approx prices (and budget) in? Hard to comment meaningfully otherwise.
how about this? around 1100 is the budget. I also downgraded to 9070.
AMD Ryzen 5 7600X 4.7GHz Processor
ASRock B850M-X WiFi rev. 2.0 Motherboard
Crucial Pro Overclocking DDR5 32GB RAM 2x16GB Modules 6000 Memory
ASRock Challenger Radeon RX 9070 16 GB Video Card
I would be tempted to get a Ryzen 7600 £165 with a £80 b650 motherboard , memory is the big cost factor as DDR5 is expensive.
How much is your ddr4 costing ?
I found an offer regarding the ddr5 so I switched to it, I also downgraded to 9070.
Nice.
You can get the 9600x for £7 more than the 7600x I would do that.
Any particular reason you've gone for that motherboard? Nothing inherently wrong with it but its a rather weak VRM so if you want more cores in the future you might want to reconsider, also worth remembering the not-quite-proved-but-still-worrying deal with ASRock motherboards and X3D chips (again if you ever upgrade to one)
I would change this to something better. If it was just a games drive then the QLC nand may be ok, but if it's your only drive then get one with TLC nand.
Crucial T500 or Lexar NM790 for example. (T500 has DRAM cache, the Lexar does not)
Also as mentioned earlier, a 1TB drive will fill up pretty quick unless you only have a few games installed at a time.
If you are getting the Thermalright Aqua Elite 360 V3 from where I think you are getting it from the new V6 version is only £7 extra and has a redesigned pump and better fans.
If it’s most for gaming, I’d be tempted to go for a 7800X3D and A620 motherboard. For the SSD I’d just buy the best £ per Gb drive you can.
The 7800x3D is close to £300 now. Finally a drop for people who don’t own one yet.
Cooling the 7800x3D with the Thermalright Phantom Spirit Evo Vision.
Owned the Evo version before, fantastic performance and noise was on check. The new version have improved fans, even better for noise. The screen was a plus, but not the main thing for me, as the case is on the left side of my desk
probably wait until AMD Ryzen 9 9950X3D2 is affordable. Can't see point of going from a 8 core to 8 core
That would depend on the use of the machine. For the £300ish mark, either the 7800x3D or the 9900x.
The 9000 series would offer better IPC, higher clocks and easier to cool.
