Rog strix 750w gold cables help
26 Oct 2010
Hello, I've been trying to find an 8 pin pcie cable and a 6 pin sata (X3) cable that are compatible with my PSU. I've never used the psu and can only find 2 cables and am in need of the other two, and possibly more in the future.
Any help would be appreciated
You can get custom cables made, but they're not cheap!
Is this one of the original Rog models? Their OEM was Seasonic (derived from a Focus GX), so their cables might be interchangeable, but I'd only try that with confirmation.
I got it in about 2019 a COVID build that life got in the way of.
I can't see any mention of seasonic on any stickers. What is a decent UK custom cable site? I looked on cablemod ant they wanted 50usd for the pair of cables
Yeah, sounds like the original Seasonic-derived Rog model.
Reviews said Seasonic was the OEM, as does SPL's tier list.
The cable site you mentioned also list them as using the same cable series.
I understand you might not want to take a punt at frying your rig on my say so.
I'm not aware of any other.
I've found some own on EBay selling spare cables, and some on AliExpress that claim to be compatible. So I'll have to double check the pins are correct and going to the corect pins on the oppersite side, on the Ali ones. Ail ones are not much of a gamble money wise.
