New pc builder here, I built my new pc to get a DRAM light on solid and just cycles error codes then restarts after a few minutes with the end code being C1. All Fans inc. CPU fan all turn on.
So far I've tried to fix it with these;
-Left running for 30 minutes in case of ram training
-Reset CMOS by both removing battery and short the 2 pins
-Tried to re-seat both ram modules into A2 B2 as before then tried them individually in A2 slot and still didn't post
-Re-seated the CPU but waiting for more thermal paste as I only had a few g's before trying again, but I did update Bios and it still had DRAM light on.
I haven't installed GPU as of yet so maybe I could try adding GPU to see if that's the cause after doing thermal paste and CPU cooler again.
Specs:
-Ultra 7 270k Plus
-Z890 AORUS ELITE WIFI 7
-XFX Swift 9070xt
-32gb Klevv Bolt Fit V ram DDR5 c30
-NZXT C850 800W
-NZXT H7 Flow
-Lexar NM1090 Pro
-Artic III Pro 360 mm
-Artic 140mm Case Fans + Artic Controller
Any help or recommendations would be appreciated.
Specs:
-Ultra 7 270k Plus
-XFX Swift 9070xt
-NZXT C850 800W
-NZXT H7 Flow
-Lexar NM1090 Pro
