** JONSBO-NANZA **
I like that D32 Pro without glass, but can't quite tell if that can accommodate two 3.5" hard drives and two 2.5" hard drives at the same time?
Not that I need it, but.....
Im sure there are places you can stick some velcro. On my nr200 I stuck my 3 ssds behind the front panel.
The Jonsbo-nanza continues :cool:
Check out these new cases we have coming in. They are due in the next week or two.
Links will update on the next website refresh.
  • SKU: CAS-JON-07865
  • EAN: 6970620555591
  • MPN: D401 Black
ATX PC case with a modern design, Glass front and side panelling, Supports up to two 360mm radiators and ten fans, Houses CPU coolers up to 169mm and GPUs up to 439mm, Spacious interior for easy installation of high-end components
£77 (incl. VAT)
  • SKU: CAS-JON-07866
  • EAN: 6970620554990
  • MPN: TK-5 BLACK
Mid tower in black, supports up to ten fans, space for radiators up to 360mm, motherboards up to ATX, GPUs up to 460mm, and CPU coolers up to 180mm in height, supports up to eight drives
£110 (incl. VAT)
  • SKU: CAS-JON-07867
  • EAN: 6970620555027
  • MPN: TK-5 WHITE
Mid tower in white, supports up to ten fans, space for radiators up to 360mm, motherboards up to ATX, GPUs up to 460mm, and CPU coolers up to 180mm in height, supports up to eight drives
£110 (incl. VAT)
  • SKU: CAS-JON-07868
  • EAN: 6970620555621
  • MPN: X400 White
Compatible with motherboards with back-connect, Spacious interior for accommodating a range of high-end hardware, Front panel with USB-C and 2x USB-A, Reinforced frame with tempered glass panelling, Dual radiator support for custom cooling loops
£120 (incl. VAT)
yes indeed. I have the setup info in my inbox.
I would expect stock around end of July, start of August.
Will post up the product URLs for pre orders when I get a chance to set them up (probably next week at this point as I am catching up from a week out of office)
Thanks...you will definitely have a sale from me.
do you expect stock for D34?
This isnt in the setup queue for us at the moment but I have checked to see if it will be available to us.
will update once I get the info
Edit*
Yes we will have D34 but it is likely not going to be arriving until late in the year.
I have the setup info for it coming across today but it likely wont go live on the site for pre order until closer to the stock arriving as we dont have firm confirmations on ETAs from Jonsbo for that line yet.
@rjk
At the risk of sounding like a broken record, has there been a delay with the Jonsbo (black/wood) D33 cases?
its just you said you would put pre order pages up a month ago, but I've not seen any sign of them
Cheers.
no problem in asking at all.
We just dont have a firm ETD for them. they are on the way to our supplier but because they dont have a confirmed date, I havent put them live as I dont like taking pre orders unless I can guarantee stock.
theyre still in the plan to list and I will have them live as soon as I get the confirmations.
Will post up in here and tag you when I activate the SKUs on the website :)
Thanks...much appreciated.
The Jonsbonanza continues... :cool:
Here we are with a bunch of new lines on pre order - ETA to OcUK is about 2 weeks so they are going on sale today.
@Cooper - tagging you because I said I would :)
D33 STD and Wood Versions inbound. A nice looking MATX case with a host of build options.
  • SKU: CAS-JON-08783
  • EAN: 6970620555676
  • MPN: D33 STD WHITE
Micro-ATX case, up to nine fans, space for radiator up to 360 mm, motherboards up to mATX & with back-connect design, GPU up to 435 mm and CPU cooler up to 172 mm height
£80 (incl. VAT)
  • SKU: CAS-JON-08784
  • EAN: 6970620555669
  • MPN: D33 STD BLACK
Micro-ATX case, up to nine fans, space for a radiator up to 360 mm, motherboards up to mATX & with back-connect design, GPU up to 435 mm and CPU cooler up to 172 mm height
£80 (incl. VAT)
  • SKU: CAS-JON-08785
  • EAN: 6970620555690
  • MPN: D33 WD/White
Micro-ATX case in white with wooden front, supports up to nine fans, space for radiators up to 360 mm, motherboards up to mATX, GPUs up to 435 mm, and CPU coolers up to 172 mm in height
£90 (incl. VAT)
  • SKU: CAS-JON-08786
  • EAN: 6970620555683
  • MPN: D33 WD/Black
Micro-ATX case in black with wooden front, supports up to nine fans, space for radiators up to 360 mm, motherboards up to mATX, GPU up to 435 mm, and CPU coolers up to 172 mm in height.
£90 (incl. VAT)
We also have their new screens inbound. These offer a flexible mounting solution and are powered/controlled by internal USB so you can customise the display however you wish.
  • SKU: CAS-JON-08789
  • EAN: 6970620555720
  • MPN: DS916 Black
Ultra-wide 9.16-inch display, USB connection and easy to use, sharp IPS panel, flexible placement options.
£45 (incl. VAT)
  • SKU: CAS-JON-08790
  • EAN: 6970620555737
  • MPN: DS916 White
£45 (incl. VAT)
  • SKU: CAS-JON-08791
  • EAN: 6970620555799
  • MPN: DS339 Black
3.39-inch display, compact with USB connection, easy to use, detailed IPS panel, flexible placement
£45 (incl. VAT)
  • SKU: CAS-JON-08792
  • EAN: 6970620555782
  • MPN: DS339 White
£45 (incl. VAT)
Just when I thought I was tired of the wood front panels. The white looks good!
Pity the screens are app controlled :( Gimme HDMI
yeah, the screens being app controlled isn't ideal really. The downside of the recent trend of internal screens being USB/low power etc is that they aren't just plug and play.
