- 25 Mar 2021
Just had a rewire done, have 12 data points around the house with cat 6 running to the under stairs cupboard. There’s a shelf that’s 600mm wide, 230mm deep and there’s space for maybe a 50mm high box.
Anyone recommend a POE+ or ++ switch that won’t exceed the space available? I can find 12 port switches that almost cover my needs but are too deep, or a 16 port Netgear one (the GS316PP) that fits the space, POE++ requirements but has 16 ports meaning wasted capacity.
Buying the number of ports you need now is generally short sighted and ultimately wasteful, buy the 16 port as it fits your stasted needs, you can then add things like IOT controllers (eg Hue Bridge), NVR, NAS etc in future. I personally don't buy Netgear any longer, the long term survival rate is not comparable to the likes of TP-Link, either in personal or professional settings, also consider if wall mounting would be better from a cable perspective, and don't ignore the generic Chinese options at this stage, you can get managed/PoE 1 or 2.5Gb switches with 10Gb SFP+ ports for very reasonabel prices now, and it will often use the same generic chipset inside, the power side can vary though.
