Comfy and supportive trainers
10 Sep 2022
essex
I'm 41m, Recently bought a new pair of trainers 2 weeks ago,, ended up with adidas cloudfoam ultimashow 2.0 trainers in an off-white grey colour look really nice and go with almost anything, they felt ok in the shop, but my god they are literally the most uncomfortable pair of trainers I've ever had the pleasure of wearing, they are not remotely breathable, the soles are rock hard regardless of the cloud foam label, the sides are too stiff and cut into my ankle when walking. My previous trainers were puma retaliate 3 and they were lovely, but unfortunately wore out and at the time weren't available anywhere. Anyway I've long had trouble with my knees and recently they have taken a massive turn for the worse and have been diagnosed with arthritis in both knees, and looks like my a kles are following suit. The Adidas trainers seemed to aggravate this and I've temporarily gone back to the pumas which have helped but I still need to get some replacements, I don't feel like I'm an old man even if my body does seem to be breaking down. I've seen sketchers mentioned a lot but looks wise they don't really go with much that I wear and I'm not quite in a care home yet. I don't really like spending hundreds of ££ on trainers, about £60 ish is where I think a reasonable budget would be (not that I can't afford higher)
I have some old cloudform adidas that im looking to replace, literally looking at the Adidas website for a direct replacement. I hope they havent changed them all too much.
Some like the Under Armour trainers a lot, maybe worth checking them out
try sketchers
I did try a pair on a couple of weeks ago and didn't think much of them. Same with a pair of under armour ones.
Though I thought these Adidas were gonna be ok but boy was I wrong.
How can you tell if a trainer is going to be comfy long term with literally a few seconds of 1 trainer on one foot.
I'm yet to find anything more comfortable than Skechers.
I'm on my second pair of these and they're very comfortable - they do wear the soles through quicker than I'd like though.
I have really bad plantar fasciitis and tendonitis in my feet due to work, I've been wearing Fitville for a while now and they're really comfy compared to normal brands and cheap enough to ruin at work. Not exactly great looking though.
My nephew is a barber, so also on his feet a lot and swears by Hoka.
Word of warning, I bought some Skechers and loved them at first, very comfortable. However, pretty quickly the inside of the shoe memory foam around where the ball of my big toes go got worn away so now it's irritating because it's got like the edges of where it's worn away sticking up into my feet risking blisters etc.
To be fair, they aren't really traditional trainers more kind of boat shoes I suppose.
Yeah I've seen those brands mentioned online, personally hadn't heard of them before.
Need to find somewhere I can try them on.
Also is it me or are men's trainers now starting to look a lot like women's trainers with the clog type soles on making it like walking on stilts lol
i would put much weight in that though . You thought your current pair were great and they turned out bad. Everyone says sketchers are comfy and they hav ed dozens of models. there vids on youtube where people compare them to the 'branded' and they compare very favourably.
difficult. Maybe your foot is weird. Try some gel insoles.
I do have flat wide feet.
The biggest issue with the Adidas is the lack of cushioning despite the cloud foam stamp on the soles they are very hard, especially compared to the pumas, the issue with the pumas is they have no support despite being comfortable, which causes more issues, but the Adidas are also quite narrow, which I did feel when trying them on but thought they would stretch out a little with wearing, but nope, also in the heat the lack of ventilation was a killer
I’ve had a couple of pairs of Hoka’s now and I really like them, I’ve got wide feet too and I’ve found the quality and support of them really good. I hiked 20 miles in the US desert with one pair, and they were fine.
I held off from Skechers for ages as the mens ones were ugly and expensive. They've updated the range now so they're much nicer.
Love em :)
If you want cushion I've not found anything better than hoka.
They wear quick though as they don't have a tough enough outsole.
I have a lot of Adidas terrex shoes. They are my main hiking shoes with a generic arched insole. The insole is essential for me too
I had to do a lot of hospital visits over the last 12 months and one thing I noticed was that the majority of the nurses were wearing sketchers. I asked one of them about it and she said they do about 25000 steps a day and the sketchers were just really comfy.
ASICS Gel Nimbus are like (funnily enough) walking on a cloud. I used a pair of 25’s to do the London Marathon last year and they were excellent, but too soft for normal running when you want a bit of support to get some speed up.
If I were 10 years younger without knackered knees, but these provide zero cushioning, and aren't ideal for knackered knees and feet
The idea is that bare foot is a way to make your feet and legs etc in general stronger. The cushioning etc is what often messes the things up in the first place.
