1st PC Build for years!!
2 Dec 2004
Under The Desk, Wales
I am aiming to build an average PC. One that can play games like GTAV, JC3, basic flight sim game, Minecraft. Nothing graphically taxing. With onboard graphics, for now.
But, with the ability of adding on a dedicated GPU at a later date.
I already have:
ITX Case
SSD Sata 2.5 Drive
Are these items that I have chosen good? Not bought them as of yet. I like ITX but willing to go Matx if cheaper. The ITX case I have has never really been used. It's about 12 year old.
1. ASRock AMD B650I Lightning WIFI AM5 PCIe5 DDR5 Mini-ITX Motherboard​
2. AMD Ryzen 5 8500G 6 Core AM5 CPU/Processor​
3. CORSAIR Vengeance Grey 16GB 6000MHz Dual Profile DDR5 Memory Kit​
4. Silverstone 650 Watt Extreme 650Rz PCIe 5.0 80+ Gold Full Modular SFX PSU/Power Supply​
5. MSI PRO MP271 E14A 27" Full HD 144Hz AMD FreeSync IPS Monitor​
What about Win 11........costly?
Any advice, greatly received.
Budget is probably max £1k.....would like to spend less if possible.
Do you NEED ITX? That usually adds cost and it could save you money to go mATX/ATX
That CPU isn't great but if you want a half OK iGPU then you're limited really, when you do get a dGPU it might well bottleneck as it's only really a 5600X/5700X level
Doesn't flight sim need lots more RAM ? (never played it) Is that a 2x8GB kit? Good for dual channel and that helps those iGPUs but 1x16GB gives you upgrade potential and you won't have filled up all of your slots - that's really a you decision.
B tier PSU, seems ok but likely adding cost as SFX
Windows keys can be brought pretty cheaply.
Not a big monitor guy so no comment there.
What's you budget and medium to long term likelyhood of upgrades?
Added budget now, approx £1k...
My daughter has an older CPU with onboard graphics and the above games play well with it.
Willing to go Matx if it works out cheaper.
Don't want to spend big money on a dedicated GPU yet as I won't be playing games at high settings etc.
Ram is so expensive as we all know so just trying to get a decent setup for now.
M-ATX will almost certainly work out cheaper, and some are fairly small despite the larger form factor.
The Lian Li A3 is a very nice little case in that regard, I think the newer B4.
My basket at OcUK:
Total: £837.85 (includes delivery: £0.00)​
The 760M is a good chunk faster on the 8600G vs the 740M on the 8500G last I checked.
You get 32gb of RAM out of the door, RAM prices are nuts and availability is poor, both of these issues seem to be getting worse so opting for 32gb out of the gate is something I'd recommend whenever it's within budget.
The only reason I've specified a 240mm AiO is because the A3 can be a little finicky in terms of what GPU/AIO/PSU solutions can be used together and the MSI A750GL is a standard sized unit. You could also opt for an air cooler, but as the A3 doesn't come with any included fans having an AiO act as an exhaust is handy.
The motherboard should be good for any future CPU upgrades on AM5 if you feel the need after changing to a dedicated GPU.
If size/space isn't really a problem there could be better cases with more fans and space in them which are M-ATX.
Reuse your existing SSD, although I would seriously consider including at least a 1tb NvME (which would be within budget) as a primary drive such as the following:
My basket at OcUK:
Total: £143.99 (includes delivery: £3.99)​
I wouldn't pay full price for W11, OEM licences are available for £10-20. Frankly, last I installed W11 it would run unlicensed with only minor functionality loss, I'm not sure if that's still true.
i would reuse your SSD for now...it's crap, but it'll do until you can get a 1TB NVME SSD as an upgrade.
just over your top end of the budget (inc monitor), but in return you get a 7600x AND a 5060 right off the bat...this will run rings around any 8600G system
the 7600x CPU cores are faster than the 8600G cores
8600G iGPU vs 5060...need I say more? :cry:
My basket at OcUK:
Total: £1,001.89 (includes delivery: £0.00)​
Considering this includes monitor (bearing in mind you already have storage) I'm actually surprised how many half decent options you can get for around £1,000 !
Also you COULD buy an 8GB GPU and save quite a bit BUT they have sometimes significant downsides so be 100% clear on what you're doing if you go down that route. They'd still destroy an 8600G obviously but it's always a toss up between just an extra £50 here or there for X% performance so only you know where to stop.
If OP sticks with integrated graphics, dropping to 8GB sticks may have a larger performance impact than expected (especially if they're 16Gbit), but I haven't seen any testing on it.
8500G is an unusual CPU, it has reduced PCIE lanes and only 2 regular Zen cores, with 4 shrunk ones. Main advantage is excellent power efficiency and low consumption.
The single/lightly threaded performance is good (because it still has 2 strong cores), but multithreaded performance is much lower than the 8600G and 7600.
If you check out this channel, he has benches for most of these rarer CPUs that are hard to find elsewhere:
My take: for around £100-£110 they're not a bad deal for a budget desktop, since you get a capable CPU with a low-end graphics card bult-in. I would not pay £150+ for this CPU though, it is too limited. With the intent to upgrade in the future, a 8600G is a better buy, though with rapidly escalating GPU prices, I don't fancy paying £500 for a 5060 in 6 months time.
Monitors aren't my thing, but I wouldn't go 1080p at 27". That's going to look like a cheap TV. Stick to 22" or 24" or upgrade to 1440p.
if this is all the budget you have then well it can work but very restrictive, but honestly gaming on dGPU is painful and very restrictive. If there is any possibility of saving up for something a little better I would and 1080p monitor are horrible, I would not do it personally. I would also not wait too long to buy GPU, the prices are going to go up and will most likely not come down for a very long time, if you are going to do anything right now is about the right time to buy.
I would NOT buy a 5060, if you are really going to game on this in any serious manner, then a 9060xt is a must at the very least. Its a good 1440p gaming card and 1440p monitors can be had for cheap. Whatever you do don't buy 8GB VRAM GPU aim for 12GB minimum or 16GB VRAM ideally.
some good system specs here, just pick one.
With integrated graphics losing dual channel will have a dramatic effect, it's also why I advised spending a bit more on lower latency RAM vs some of the cheaper 6000 options.
For the sake of a tenner (at least on OCUK), the 8600G is a much better buy tbh, it has double the CU's and shaders which relates to around 40% more in game performance.
Going for a dedicated GPU and 7600X might very well be the best option, it does depend on long term intent but with the market as it is god knows what will even be viable in six months time, if you can spending extra out of the gate is probably the best option.
PS: RandomgamingHD is a great channel, especially for budget building, been following him for years.
Do you specifically WANT on board graphics for any reason? (power, form factor etc.)
Otherwise I'd probably not bother with the G CPUs and just chuck in a 2nd hand card like a 1070 in there, they can be had very cheap (one went for 'free' plus a charity donation last week - collection only but you could find something similar for not too much - probably less than the gap from a 7600X to an 8600/8700G).
8700G is slower than a GTX1650, but a 1070 is a bit above a 1660ti !
Edit: 1070 is actually closer to 1:1 with 1660ti, but 2GB more VRAM... still much better than onboard and with the RAMpocolypse showing no sign of ending, going 32GB dual channel now would seem a better investment to me
Ok, so, if I went for an ordinary CPU and a dedicated GPU, which combo? I haven't a clue as I have always had onboard graphics.
The 8600G looks good otherwise.
ITX was choice as I like the small form factor.
Budget is low but I do want to get best bang for buck with option to upgrade in the future.
I greatly appreciated everyone's advice. Thank you.
Failing that, what would be a good Matx motherboard and ram to go with the 8600G?
Ta
7600X is £140 at OCUK. It performs the best of all those CPUs (including 8600G, 8500G) and is the one to pick if you will not be using the graphics to play games. 9600X is worth it, if you can find it for just a little more, but it may require a BIOS flash if paired with B650. Neither of those CPUs has coolers included (only 7600/9600 non-X do).
If you will be using the graphics, then the 8600G is a better CPU than the 8500G and it has significantly faster graphics. Both CPUs include coolers.
I would get either the 5060 8GB or a 9070 GRE, but not the 9060 XT 16GB. My reasoning is: if you're sticking in the £300 range then the 5060 is the least price hiked of the available cards. The 9060 XT 16GB is a whopping 30%+ more expensive than it was on release and while a 9070 GRE is 10% more, it is more like 30% faster.
The 5060 is a solid card for 1080p and capable of 1440p (with the games you listed), but the 9070 GRE is in a different class of performance entirely, not far off a 5070 and similar performance to a 3080. If you're moving up to 1440p, then this would be a better option longer-term.
