What have you done to your car today?
it randomly reboots one of the control modules as you are driving it. Does the *bingbong* you've just switched me on sound, dash lights all come on, seat belt and airbag lights come on. Climate control goes ballistic (max cold > max hot then usually settles down but not always). Cruise switches off, mostly switches back on, sometimes doesn't. Sometimes it will then also decide that a door is open, or the ADAS doesn't work. In summary it is flaky as hell.
does the car log these reboots , and the dash dead problem too , so they should be able to confirm faults
-if- you can get them to honestly show what is logged.
Ah got it, I know there were issues with SOS randomly ringing emergency services. Surprised they only last 3-6 yrs
The last big OTA update killed a lot of them as well as it apparently chopped 25% off the reported SoC but VW will only possibly replace for free if the error popped up shortly after updating.
I have no idea. I'm sure they won't do any more than get the work experience kid to plug an OBD reader in then use it for the lunch time McDonald's run before saying "couldn't find anything wrong with it, that'll be £170"
I was bitching about it at work when I got "that's the great thing about electric cars, you just run them for 8 years without even thinking about them". Ironically coming from someone who's Kia Niro BEV lives at the dealership with various issues. I'm not sure poor build quality and software issues can be attributed to any particular fuel source either :rolleyes:
fear of being at the mercy of the dealer for OBD diagnostics is one of the rerasons I've just about justified spending £100 on a diy reader
(more overthinking - sorry diddums)
for my Audi, so I could have diagnosed the brake servo assist sensor failure and I can get rid of the pesky 'oil change is due msg' on every start.
clean MOT completed today, surprised it hadn't gone up at £45, twas the day it was going to expire,
but I suppose it doesn't matter when it is done - if it failed I couldn't continue to drive it until expiry date anyeway ?
I have Torque Pro and a Bluetooth dongle thingy. I have zero faith it will have a stored code that I can read but it's worth a shot.
My wiper linkage broke so got 2 repair clips to go on the ball and socket (used before they work well) 1 to fix one for prevention, I have a wiper arm puller so that makes life a little easier
Also a puncture repair
My weekly AliBaba mod for my Model 3 :cry:
Spent some more time yesterday digging into the Celica, cutting out some bits around the rust, making some templates and generally working on this rust repair. I just keep finding more rust though :eek: :p
'Scary' bit at the end of the day was finding/making a hole in the frame rail, had thought that was decently solid but nope, so yet more that needs cutting out and replacing. It's one thing finding like the outer sill is gone but the frame seems a touch more important :p
Any sane person would've called it by now I feel, certainly anyone paying a garage would've been done before even starting, but seems I'm crazy enough to keep going... It's only my free time and already bought the sheet steel so why not!
Sounds like a skill issue.
(Post up a thread, be nice to see what you're doing)
Not all today but...
Failed MOT due to headlight beam too low. The adjustment nut is freely spinning and not changing the level :/ Ford want £1200 for a replacement... so I managed to get one off eBay for £500 that looks to be in good condition (a lot of them look garbage and have various bits of damage). Waiting for that to be delivered ...
Also repairing the 'rust' bubbles (it's Al₂O₃ but close enough) on the bonnet. Sanded it down and painted it, waiting for it to cure before I try and blend it in.
Once it's blended and I get a day of decent weather (where I'm not working...) then I'll give the whole car a few passes of correction polish then finishing polish.... then I've got some Crystal Serum Light and EXO to coat it.
Waaaat
interesting -what primer did you use ? had to do some parts of an alumium bike frame a while back requiring some research - the jury is out,
and have some other anodized aluminium I am thinking of tackling.
https://www.amazon.co.uk/Hycote-Bodyshop-Build-Primer-400ml/dp/B004SHJQ42?sr=8-8
Can't say I've used any other primers, but this one did the trick. Used Hycote cans for primer/colour/clearcoat - so far so good.. Just gotta see how well it looks once it's sanded and polished :D
I can't imagine trying to do a rattle can blending job on a 2018 Mustang. :p
Bodyshop job surely!
I think modern Fords are quite well known for corrosion problems before the age where it should really be a concern. I've heard of quite a bit. Though usually it's the steel on the underside on badly protected seams and things rather than this...
Friend of mine over in the US has holes in the frame of his 2017 F150. :p
And I vaguely remember someone on here rejecting a brand new Ford Ranger (?) because it was going rusty when it was a couple of months old.
