PS5 Controller issues / PS5 on windows settings
24 Jul 2008
Good evening guys.
I have been having some issues with my Ps5 controller.
Turn on PS5 with controller ok
Start game ok
Game loads , i click start game and nothing happens i have to turn off controller and back on and i can use in game.
Rocket league same, unable to use L2 /R2 in menus but can drive with them in game fine.
Spiderman he just constantly swings and fires webs, deffo some trigger issues
Now prior to me switching back to PS5 for a gaming fix , i was using the PS5 controller on windows PC and had some compatibility issues with Forza 6 and used a number software to try and get it to work and mess with a lot of settings.
Not sure if i really balls something up with it and now its a mess.
Tried removing it and the pin hole reset on the controller nothing, controller seems fine as all buttons are working.
Just behaving odd in some games and menu's
any advice? anybody had this?
Are you using it wired on PC or via Bluetooth?
Does it work fine on PC still? And the issue is only on PS5?
ive not actually re tried it on PC yet.
It does it wired and bluetooth on PS5
I'd try it again on PC to see if the issue is there still on that.
The other thing is Sony added multiple paired device support a month or so ago, it could be that even when you're pairing it with your PS it's got something stuck with the PC pairing? You should be able to check the different 'pairings' by the below and see if that helps.
I have tried it on my PC again today wired im still getting issues.
R2 is an issue.
I think the controller is on its way out :(
Still cannot use R2 on menus in games.
I tried rocket league and firstly the car just moves ever so slightly forward without touching the controller.
Up above i have posted D4S screen shot for windows and you can see some input on the R2 whilsts its idle.
Both wired an bluetooth, not sure if its worth taking apart.
Luckily i have a brand new spare controller in the loft somewhere which i picked up from a stupid black friday deal years ago, so looks like that needs locating and breaking out.
Also picked up a xbox windows controller for my PC now too , saves me using same for both.
