- 13 Sep 2010
This is my main concern... I'd really like to ditch Windows at least as my main OS and was thinking of trying cachyOS, but there are a couple of games that I'd need to dual boot for, due to mostly arbitrary business decisions around anti-cheat. (Skate. being the main one - not even sure why a skating game needs robust anticheat! but would also like to give Wardogs a try.)EDIT: Forgot to add - dual booting - I wouldn't do it, but that's me. I did try it once on separate drives, but I had issues. Particularly with Windows removing the boot loader. You can work around this and try and limit the configuration. But it's full of issues. Ideally if you have a way of separating your Windows and Linux PC's I think that's a far, far easier life. Again Steam OS lends itself quite well to this in that you can have a second PC in the lounge running Steam OS.
I have a spare 1TB nvme (it's currently just an old backup of my windows and games partitions, before I cloned them to a larger drive) and had heard that if they're on separate drives then it's not too much of an issue, but had seen a few things about boot loaders being an issue.
But I had another idea and am curious if it could potentially work - Would appreciate any insight you may have.
If I were to install Cachy on one NVME, and Windows (10 btw, I'm on ESU and my dislike for W11 is the main driver for this!) on the other, then rather than a typical boot-loader setup, just switch between them by changing the boot priority in BIOS (i.e. having a separate boot loader for each, that hopefully couldn't see each other), would that solve the issue?
A second 'lounge' PC isn't really an option I want to explore... in large part because my main PC is already in the living room and connected to the TV with a long HDMI cable (upside of living alone I guess), so my choices otherwise are basically to grudgingly stick with Windows, or copy anything important to my NAS and accept the fact that I may have to reinstall one or both OS more often than I'd like.
Tbh I don't really understand why they couldn't co-exist and even share a games partition (since they both support suitable filesystems), but I assume that's MS doing everything they can to make it difficult for people to move away...
