Gamers, What's Your Audio Set Up?
This will blow your mind then.. the larger one is the right speaker from my amp which my tv and PC are plugged into... the smaller one is the left speaker plugged into my PC directly for desktop use.
I use either of them for games, music and TV/movies depending on where in the room I'm sat. Crazy, I know, lol! ;)
This is not a sub forum, this is a thread about gaming audio setup, but seems to have just become a HiFi earphone thread, again when was the last time a game was mentioned not a CD or Tidal audio etc.
Me with the announcement of the new PlayStation headsets for 2027 a few posts up!
I'm going to be a pedant, in good humour mind you, and point out that the thread title is "gamers whats your audio setup", and isn't directly implicit in it means only for games. the first post, also asks about what use you put it to. I think most people here do actually use it on their pc. I know I do, I upgraded last year to a Luxsin X9 driving a pair of Acoustic Energy AE1s, and I've got a couple of headphones for different purposes. I also put a custom waterloop and 3 420mm rads in my case recently, so I can run my fans virtually silent at idle - and when I listen to music, I quite often sit there and go "wow". I also game on this, and again it sounds great.
I've really enjoyed reading this thread this past year and a bit, although when my wallet is empty I tend to stay away from it - when in reality it should be the other way around.....
That is indeed pedantry. :p It is very much implicit that gaming is the focus of the thread, in that I specifically addressed gamers in the thread title. And although I asked if your gear was used for movies or music also, it was very clearly stated as being in addition to gaming, but 95% of posts here don't even mention gaming (or movies either for that matter). :)
I just realised, slowly, 1 plane ticket at a time (I bought 3 return flights), scuba course/gear rental, hotel, food, airport parking and fuel....I am at least £4k deep for my SE Asia trip in a couple of months.
That's one heck of an audio upgrade if I spent that on amps and headphones.
Any advice on a great new speaker set up ? do a lot of gaming, music on youtube etc, thinking on the Razer Nommo V2 Pro or the Edifier M60
Any advice on a great new speaker set up ? do a lot of gaming, msuci on youtube etc, thinking on the Razer Nommo V2 Pro or the Edifier M60
I love my M60's... absolute steal at £120 at the moment.
The nommo v2 pro has a sub and is closer to £400, unless you mean the non pro (2.0 rather than 2.1), which at around £120 I just can't imagine being as good as the edifiers, but I've not listened to them, they look more style over substance to me.
The m60 also has bluetooth, an EQ app, and whilst the total output is roughly the same, they has a separate tweeter and mid bass driver, which is also bi-amped and bi-wired, it's quite the package for £120.
Total Output Power (RMS):
Treble 15W x 2
Mid-low 18W x 2
So on paper should be a much better sounding package.
I use Edifier MR4 for gaming/music when not using my Hifiman XS.
Doesn't have the Bluetooth or EQ app that the M60 has but the MR4 has balanced inputs unlike the M60 so depends on your needs/setup. These would be called studio monitors rather than PC speakers. There's the 4.5 now which you could take a look at that does have Bluetooth.
I took delivery of a pair of these balanced XLR to TRS from China today. Seemed really cheap so took a punt and seem to do the job.
I used to have the MR4s as well, superb speakers for the money and size. My mate bought some on my recommendation and also loves them. I think Edifier replaced the model with the MR3 now, but it's the same speaker.
  • Like
Reactions: maj
Would you say they need EQ on them?
Presumably the MR4 is close to end of life if not already. Seems OCUK have the MR3s for only a tenna more than I bought the MR4s only a few weeks ago so may have gone for them instead oh well. I at least supported a local business when I bought them so that's a positive.
Depending on which reviewer you watch, some say go for the MR3 and others say the MR4 based just on the sound. It's all subjective anyway.
Now that I've got the balanced XLR to TRS cables, looking to get some speaker stands to point them up rather than being flat on my desk.
As I understand it the MR3 is a slightly cut down cost optimised version, so while basically the same speaker its probably better sticking with the MR4 anyway. The need to EQ depends on your room, as with any speaker. In my old office, I found it sounded good without any, looking at the reviews that measure them they are pretty flat with fairly deep bass.
  • Like
Reactions: maj
Some changes to what I currently use for PS5 gaming and PC working during the day. Picked up a set of Fiio JT9 open backed headphones to use with my Meze Boom Mic - makes a superb, comfortable headset as well as a decent audio option. Using either the Topping DX1ii or Fosi C3 with them - Topping sounds marginally better to me but the mic input and AI noise filtering on the Fosi are far, far better. I'm getting an annoying high pitched background 'squeal' on the Topping which has currently relegated it to single player gaming only.
I've found another gaming orientated DAC/AMP: Douk Audio x GD Lab Z1
From a reddit thread, although that looks a bit AI generated, so I won't link to it. Apparently this Douk DAC/AMP/Mixer is a collab with a YouTube channel, but also adds some streaming capabilities to it (XLR mic input/48V). It's available to buy although I can't see many well known reviews of this thing yet.
Again great to see gaming options, i.e. DAC/AMPs with mic input that work on PC, PlayStation & Switch. Gone from having very few options to now having a number of them.
Looks good - found this video also
Seems to have a lot of features wrapped up in that design.
Got it!
Took me a while to fumble the input of the Fiio to get it working, the usb cable (usb-a to usb-c) I had turned out to be power only and all I got was a crackling noise!
No usb-c out in the back or the ET3 so can’t use my new usb5 cable.
Anyway, has an optical cable lying around and it finally worked!
Ps this thing for the money does not come with any audio cables, just power cord, nor any battery for the remote.
Just to see, it’s the same width as the K13
