Really Useful Boxes and exploding cans
1 Apr 2014
Aberdeen
I've got a Really Useful Box which has contained the explosions of cans of baked beans and cans of tomatoes. And I didn't notice for a while. I've cleaned most of it but there is a residue that is resistant to soap, water, and elbow grease. What else is safe to use? For example, can I use oven cleaner?
Aside from the old white vinegar/water mix and left for 24 hours, the next step is UV bleaching, so pop it outside on a sunny day, or buy a UV lamp and leave it in the box for a while..
oven cleaners fine - have used it on plastic bins & buckets to shift organic grime,
citric acid/vinegar when it has also got some water stain/calcium carbonate component.
I was going to suggest crushed up dishwasher tablets with a bit of water to make a paste but the OP has confirmed oven cleaner has worked.
Both are heavy duty degreasers.
I’d avoid things like cif and pink stuff on ‘soft’ plastic boxes because it’s pretty abrasive.
