3D Prints Gallery
Yep it uses 608 bearings (Venom skateboard), but the bottom one has already jammed, doesn't help that they're flat so crap from the garden can get in.
Have you tried printing the bearings? I’ve done a few before, they print in place and then I put a bit of grease in and they are surprisingly smooth!
608zz are more sealed though have grease so you'd need to flush some of it out to get the best out of them but they should work better.
I use them on the spinning platforms my youngest daughter models clay on, it can get dusty do made more sense.
What do you use to flush the grease out?
Iso alcohol, just let them steep for awhile and some will break down and come out through the gaps on the metal shields, leaving a little in is ok but if there's too much packed in then it takes more torque to make them spin.
Halloween mask, split in to 5 parts and then glued together.
Printed a copy of racing drivers off for my sim rig!
