Thank you for your patience while we work on setting up your account. Your account is very close to being fully set up, but we have encountered a slight issue with registering your export MPAN. Please don’t worry, as we are actively working to resolve this.
Ah fair point. Maybe Kraken is throwing a hissy fit, but it shouldn't be the case as @b0rn2sk8 's SEG transfer went without hitch and we're both transferring from Octopus...They need to register it into their system. Not the same as applying for one![]()
Have you had another "you're leaving" email from Octopus since you transferred import?Ah fair point. Maybe Kraken is throwing a hissy fit, but it shouldn't be the case as @b0rn2sk8 's SEG transfer went without hitch and we're both transferring from Octopus...
Puzzled face
I need my best compo face if they stuff it up![]()
nope. only the original email when i transferred my import.Have you had another "you're leaving" email from Octopus since you transferred import?
whilst they both use kraken I get the feeling they use it differentlyAh fair point. Maybe Kraken is throwing a hissy fit, but it shouldn't be the case as @b0rn2sk8 's SEG transfer went without hitch and we're both transferring from Octopus...
Puzzled face
nope. whole home.EDF extra slots are car only I thought ? Edit. Just looked again. Damn AI lying to me.
its so bloody sure sounding sometimes!nope. whole home.
ignore the AI hallucinations lol
That's strange, I feel like I get a lot more peak slots from EDF compared to octopus.whilst they both use kraken I get the feeling they use it differently
since getting EDF my car has always charged in off peak, no extra slots.. but OTOH it has not changed my charging schedule after it was created either
this is both a good and a bad thing. extra cheap electricity is always nice... but OTOH it makes managing my house battery a pita if the slots keep changing.
none of which explains the SEG issues (everything silent about mine as well)
Apply after your import switch compiles and it will appear on the form.When I apply to move my SEG to EDF the only tariff option I get is the 3p/kWh - guessing they can adjust it to the 13p/kWh version once my electric import has moved over?
They don't really mention it anywhere on the SEG application form!
That’s what happened to me, I waited until it was there.
You are only talking about a matter of days in reality as your switch should go through in 3 days.
