New gaming rig
6 Jun 2023
UK
1440p gaming
My budget is £2k
I'm looking at the 5070ti but would consider the 9070xt.
Any input would be appreciated
Cheers.
AMD Ryzen 7 9850X3D
Thermalright Phantom Spirit 120 SE
Gigabyte B850 AORUS ELITE WIFI7
Klevv BOLT V 32GB DDR5-6000 CL28
Crucial P310 2TB NVMe SSD
Phanteks Eclipse P600S
MSI MAG A850GL PCIE5 850W Gold
White mid-tower build alternative that's closer to budget:
My basket at OcUK:
Total: GBP2069.81 (includes delivery: GBP0.00)​
Spend the extra on a 9800/9850X3D if you can afford it.
Weirdly easier to put a white build together currently due to the stock issues.
You're going to need to rein in your expectations with the state of the market right now, putting down £100-120 + on a case like the Phanteks P600S isn't sensible and you're not getting a 5070ti/9850X3D build with a £2000 budget.
My Basket @ OCUK.:
Total.: £2201,76
1440p gaming
My budget is £2k
Cheers.
AMD Ryzen 7 9850X3D
Crucial P310.: bad qlc memory chips like TOSHIBA Exceria G3 / MSI MAG A850GL .: CapXon, TEAPO, ChengX capacitors.: SO/SO
Phanteks AMP GH 750W ATX 3.1 PCIe 5.1 80 Plus Gold Modular Power Supply - White (SKU: POW-PHK-02518).:
sleeve/bearing fan
It comes with white braided cables and combs too!
All products within a strict budget and/or theme are going to have a certain amount of compromises, the AMP GH is a good PSU but it's certainly not the best of the best. The G3 NvME is similar in this regard, it's QLC yes but modern QLC is not necessarily bad depending on use case, you need to look at TBW (aka endurance) which is very high with that particular drive. For a media production/work based rig then a higher quality drive with DRAM is worth spending the extra on, for a gaming or entertainment machine it simply isn't.
QLC only like second SSD, not for the system
FSP VITA 750GM vs Phanteks AMP GH750W .:
Better Platform.:)) FSP originally vs Helly's
Cybernetics Platinum Certification
600W 12V-2×6 vs 450W 12V-2x6 limit
Warranty 10 years vs 8 years Phanteks
IN Black.:
7800X3D vs 7700X3D
Frequency 4,2/5 GHz vs 4,0/4,5 GHz
Difference 500MHz in Boost is Big Difference, this is not 100 or 200MHz,
Because 7700X3D at start was 1,5 times cheaper than 7800X3D
My Basket II@OCUK.:
TOTAL.: £2139.79
