Calls for AMD to bring back 5800x3d
Yes was going to say a few days ago, I went 5800x3d as in my case it made sense, but if only currently have 16gb it makes to upgrade platform as that is the main factor.
Or drop in another 16gb DDR4 kit for cheap. Assuming memory capacity is a bottleneck of course.
Does anyone have any idea if these new 5800x3d overclock at all. I know the original ones didn't due to the design so was wondering if the redesign had made any improvements to their ability to be pushed that little bit ?
It’s the same as the old chips. Negative offsets
first time seeing this thread, I have been considering buying one of these. But I only upgraded, from 2600 to a 5600 last year. That was a very noticeable upgrade. Can’t decide if I want to max out my current AM4 rig and hold onto it for as long as I can until AM6 drops.
I stand by my previous post in here:
With a 5600 then I wouldn't bother unless you actually need the extra cores for productivity apps.
Personally I think the recommendations for AM4 owners are as follows:
- Existing 4xxx generation or older - for gaming only > buy 5500X3D or 5600
- Existing 4xxx generation or older - for productivity and gaming > buy 5800X3D Anniversary
- Existing 5700X / 5800X / 5900X / 5950X > only consider 5800X3D Anniversary if the games you play actually benefit (and especially 5900X/5950X will lose performance in productivity)
- Existing 5500X3D / 5600X / 5600X3D > consider 5800X3D Anniversary only if you need more cores (e.g. Productivity)
- Existing 5700X3D / 5800X3D > do nothing (consider upgrade to AM5 if you need more performance / cores)
That’s a fair assessment.
I'm getting quite heavily in to Wardogs and apparently it really benefits from the 3d cache.
It seems to be running really well.
I don't think it's a redesign, it's just the same chips re-released IFAIK
It’s different, but for all intents and purposes it’s the same. Some data says the new revision is slightly better, but at best the gain is maybe marginally outside the margin for error. That’s at least from what I’ve seen, but I lost interest in the revised Zen3 because it was single v-cache chip.
How worth it is the 5800X3D if I am currently running a 5700X ?
I realise not all games use the 3D cache well. But on the flip side, with prices trending as they are, it might be many years before I can do a full system rebuild
Yes and no.
It very much depends on your circumstances, what £300 is worth to you, how much it'll niggle you.
For me I went from a 5800x to 5800x3d, so even less of a margin than your scenario.
For me, as my system already has 64GB of memory, moving like for like on the next platform, due to memory prices was just not an option. The other thing is my system was/is running well, and I didn't fancy the hassle/stress/cost/potential issues of a full platform change. Plus honestly, I was pretty happy with my system anyway and not thinking of a platform upgrade regardless.
I had the 5800x since release, and when the 5800x3d came out the first time, I decided against it, but it always niggled at me a bit, so there is that as well. So now that niggle is gone, and I am happy sitting here thinking this platform is at its most optimum, and have no urge or desire to upgrade or move platform and I can't see that changing any time soon.
As for the upgrade itself, not a huge difference on top end FPS, but the minimums definitely got improved, but not only that, but the whole system feels "smoother" is hard to describe any better than that, and that's not just in games but windows generally.
I don't regret it at all, and for me I think it made sense.
But it very much depends, if you only had say 16GB memory on your current platform, it may make more sense to think about a platform upgrade, as the cost of that (although still horrendous for what it is) its a much smaller pill to swallow.
You should notice a difference in intensive games.
No idea how long the 5800X3D 10th anniversary CPUs will be around for, but if you are considering an upgrade it might be worth doing it sooner rather than later. Prices are sure to go up if the 5800X3D becomes more scare again.
I went from a 3800xt to 5700x3d the above statement reflects my personal experience,although i did get a boost to top end fps but i was on a 3000 series chip even the non x3d 5000 series was a significant upgrade.
Only £289.99 at OcUK and we also have the lowest prices on DDR4 as well:
  • SKU: PRO-AMD-08286
  • EAN: 0730143318471
  • MPN: 100-100000651POF
100-100000651POF, 8 Core with 16 Threads, 4.50GHz clock speed, 7nm FinFet Process, 96MB L3 Cache, Dual Channel DDR4 Controller, 3600MHz RAM Recommended, 3 Year Warranty
£314.99 (incl. VAT)
£289.99 (incl. VAT)
For those of you who missed out on some of the KLEVV deals, I've dropped the prices again with no limits on quantity (1pc per customer however) and no time limit, that shall be at my discretion.
£398.99 - Competitors for a CL30 kit are £500 - £700
  • SKU: MEM-KLV-07036
  • EAN: 4895194968795
  • MPN: KD5AGU880-60A300L
KD5AGU880-60A300L, 6000MHz RAM Speed, CAS 30-36-36-76 Timings, 1.4v UDIMM, AMD Optimised
£479.99 (incl. VAT)
£419.99 (incl. VAT)
£399.95 - Competitors for a CL28 kit are £550 - £800
  • SKU: MEM-KLV-09257
  • EAN: 4895194969075
  • MPN: KD5AGU880-60B280F
DDR5 RAM kit with 32 GB (2x 16 GB), 6,000 MHz clock speed, CL28 latency, low-profile design, Intel XMP 3.0 & AMD EXPO support
£499.99 (incl. VAT)
£469.99 (incl. VAT)
We do have more Lightning deals commencing Monday which will feature V-Color higher frequency kits (6400-8000MHz) and some low latency 6000MHz Patriot kits. The faster latency kits won't be under £400 however, except for the 6400 kits which are C32 and shall be £399.
Nothing has changed, memory prices continues to increase in price for DDR5 whereas DDR4 prices have actually dropped a little and to reflect these price drops we are the cheapest by miles (upto 50% cheaper than competitors on DDR4 SKU's:
  • SKU: MEM-ADA-08419
  • EAN: 4711085942791
  • MPN: AX4U32008G16A-SBKD35
DDR4 RAM stick with 8 GB, 3,200 MHz clock speed, CL16 latencies, low profile, Intel XMP 2.0 support
£68.99 (incl. VAT)
£49.99 (incl. VAT)
  • SKU: MEM-ADA-08330
  • EAN: 4711085943279
  • MPN: AX4U32008G16A-SBKD35G
DDR4 RAM stick with 8 GB, 3,200 MHz clock speed, CL16 latency, low-profile design with RGB lighting, Intel XMP 2.0 support
£79.99 (incl. VAT)
£59.99 (incl. VAT)
  • SKU: MEM-PAT-08326
  • EAN: 0814914025505
  • MPN: PVS48G320C6
£79.99 (incl. VAT)
£64.99 (incl. VAT)
  • SKU: MEM-ADA-08331
  • EAN: 4711085942838
  • MPN: AX4U320016G16A-SBKD35
DDR4 RAM stick with 16 GB, 3,200 MHz clock speed, CL16 latency, low profile, Intel XMP 2.0 support
£119.99 (incl. VAT)
£98.99 (incl. VAT)
  • SKU: MEM-ADA-08408
  • EAN: 4711085942807
  • MPN: AX4U32008G16A-DTBKD35
DDR4 RAM dual kit with 32 GB (2x 8 GB), 3,200 MHz clock speed, CL16 latencies, low profile, Intel XMP 2.0 support
£128.99 (incl. VAT)
£99.95 (incl. VAT)
  • SKU: MEM-ADA-08424
  • EAN: 4711085943286
  • MPN: AX4U32008G16A-DTBKD35G
DDR4 RAM Dual Kit with 16 GB (2x 8 GB), 3,200 MHz clock speed, CL16 latency, low-profile design with RGB lighting, Intel XMP 2.0 support
£139.99 (incl. VAT)
£104.99 (incl. VAT)
  • SKU: MEM-ADA-08422
  • EAN: 4711085943316
  • MPN: AX4U320016G16A-SBKD35G
DDR4 RAM stick with 16 GB, 3,200 MHz clock speed, CL16 latency, low-profile design with RGB lighting, Intel XMP 2.0 support
£124.99 (incl. VAT)
£104.99 (incl. VAT)
  • SKU: MEM-PAT-08325
  • EAN: 0814914025512
  • MPN: PVS416G320C6
£149.99 (incl. VAT)
£109.99 (incl. VAT)
  • SKU: MY-105-PA
  • EAN: 0814914025376
  • MPN: PVS416G320C6K
PC/Server 16 GB DDR4 Dual-channel288-pin DIMM 2 x 8 GBCAS latency: 161.35 V
£139.99 (incl. VAT)
£109.99 (incl. VAT)
  • SKU: MEM-ADA-08407
  • EAN: 4711085942845
  • MPN: AX4U320016G16A-DTBKD35
AX4U320016G16A-DTBKD35, 3200MHz RAM Speed, CAS 16-20-20 Timings, 1.35v UDIMM, Lifetime Warranty with OcUK.
£259.99 (incl. VAT)
£199.99 (incl. VAT)
  • SKU: MEM-ADA-08423
  • EAN: 4711085943323
  • MPN: AX4U320016G16A-DTBKD35G
DDR4 RAM Dual Kit with 32 GB (2x 16 GB), 3,200 MHz clock speed, CL16 latencies, low-profile design with RGB lighting, Intel XMP 2.0 support
£269.99 (incl. VAT)
£209.99 (incl. VAT)
  • SKU: MEM-KNG-06865
  • EAN: 0740617319873
  • MPN: KF432C16BB1K2/32
32GB, 2 x 16GB RAM modules, DDR4, 3200MHz, 16-18-18 CAS timings, Dual-channel configuration
£319.99 (incl. VAT)
£259.99 (incl. VAT)
Our DDR4 pricing is pretty legendary in the current market, literally as much as 50% below some competitors, just to also make it clear DDR4 prices have not dropped by 50% the actual drop is in the 5-15% region direct from IC giants, the reason OcUK is so cheap is because I was stock piling months ago, just as I've done on DDR5 to in short be able to be the market leader on memory going into Q4 and into Q1 next year, the massive cash investment was worth it as were able to bring you our customers memory prices typically 10-50% below competitors and somewhat ease the pain of the price increases.
Next year however will be a totally new ball game and at somepoint memory pricing will become truly horrible unless a truly mammoth change happens in AI but so far apart from some ripples in stock markets the wholesale cost in general are still trending upwards apart from DDR4 / DDR3 and NAND. DDR5, GDDR6/7 and HBM are still moving higher.
