RTX 5090 End of Life, new 24GB RTX 5080 coming
IMO the 5090 should never have been a general consumer GPU due to its obscene power draw, Something better suited to server racks with the direct to PCB power connector and current balancing which is absent on the consumer side.
I’ve recently undervolted mine and it’s pulling high 300s to 450W max now. Runs 10-15C cooler with no performance loss. No brainer for anyone using one.
Yeah but it's the pin imbalance that's the danger, Too many amps go to 1 pin and welcome to melty town.
I agree it's not ideal but there are plenty of fail safes now in the form of cables that have auto shut off feature, PSU's with built in per pin monitoring, and of course the WireView 2.
I definitely I think Nvidia could have released the 5090 with tighter and more efficient default voltage-frequency curve though, as you say the default power draw/curve is crazy.
They could've put current balancing on the card connector side but chose not to, I think that's such a bad design flaw.
Yeh it’s not ideal but I guess the percentage is still really low. We obviously hear straight away about when it happens though of course making it seem more common than it really is.
Lots you see are from using adaptors or the cable having a tight bends. Also making sure you are not constantly removing the connector and keep checking as the connection will potentially get worse each time.
Wireview etc for peace of mind though.
All to squeeze a few dollars saving on a $2000 card, and some PCB space (no doubt allowing a larger cooler).
They did spawn a new market for fancy cable and power monitoring peripherals though.
I wonder what they'll do for the 60 series. Even if gaming is low priority to them, surely 2 generations of bad press merits reintroducing current balancing for the top end in some form or will they just rely on 3rd party.
Should just let the market decide, stop mandating the 12VHPWR for cards above a certain tier. If an AIB partner wants to make a card using 8pin pcie connectors, even if it means having a row of 4, they should be allowed to. Then let the people decide, want the 12vhpwr, go to a card that has it, don't want it, you can stick with normal 8 pin and go for a card with them.
That would be giving away control, which clearly Nvidia is unwilling to do
Cannot use wireview pro due to side panel clearance. Just got a MSI ai1300ts and so far only pin 2 is a bit higher around 0.2 to 0.4 than other 7 pins.
That’s fine. Mine are super tight though, to the point that when I was trying to test the functionality and make sure my script worked, I had to reduce the tolerance to 0.1 to have any chance of it going off.
Was surprised how much bigger it was too over my 1000w.
Wireview pro wired version?
Normal version.
I was thinking between wired version or new PSU with monitoring function, at the end I went for new PSU as I already have MSI center installed.
Personally I won't use the adapter which came with my 5090, it looks bulky and heavy, I feel it put pressure on the connector which I don't like.
Before the new PSU, I was using 12VHPWR to 4 x 8 pin cable from cablemod as my old corsair psu, the cable still looks new when I took it out.
Price rise incoming with that news then ;) Nvidia just doesn't want to admit eol for the 5090 and leave people guessing.
Just guessing but I'm guessing it would impact stocks if they suddenly announce all their 5090/GB202 silicon is now strictly for their "new" RTX 5500 Pro while leaving a gulf at the top of their gaming stack.
Should go up, profit margin is higher on the 5500 Pro. I guess they’re just trying to avoid backlash from us “gamers”.
Based on how they price their things even at MSRP, I don't think they give a damn about what gamers think. Nvidia could liquidate GeForce and it would only look like a rounding error on their books.
