Energy Prices (Strictly NO referrals!)
How did you manage that? We're with eON, tariff ending soon and their supposed neat offer is £212pm for 12 months. Cheapest unit price for leccy is 16p between 2-5am.
EDF go electric EV tariff.
Would it mean if in a fixed the standing charge would remain until the fix ends by which point the standing will be loaded into the unit anyway?
Bye bye gas SC...
The unit prices of gas will increase, so high users of gas might actually be worse off. Luckily I'm a reasonably low user of gas, so I shouldn't be affected as much as high gas users.
Getting rid of the standing charge and piling it onto the unit price is just smoke and mirrors.
From sky news:
'The chancellor has announced that standing charges on gas bills will be scrapped, as the government looks to make energy bills cheaper.
According to the Treasury, it will save around £45 per year on the average bill.
John Healey has asked Ofgem to deliver the policy change in 2027 or "as soon as possible".
The standing charge is placed on all bills, regardless of use, and is used to fund maintenance of the gas network.
These costs will instead be paid for through a slightly increased cost of each unit of gas used, the Treasury says, estimating a saving of 60%.'
Seems like a fairer way to do it though, make more use of the network then pay more to support it. SC is 50% of our daily cost for a large part of the year currently.
Yeah I agree.
Also a fairly low user though so should benefit slightly. But all those people in older houses who can't afford to spend loads on insulation are going to suffer. It's the vimes boots theory all over again.
As I'm currently on a cheap deal (until March :( ) the gas SC has been more than double my gas consumption.
I expect this will be moot for me.
I find my situation in many demographic things to be "average".
Average house price, average house size, average utility bill (except for electricity).
So I expect a shift from standing to unit will just make no difference to my bill.
Is not a bad idea as it will push heat pump adoption I guess. Unless you have an old house that is poorly insulated or expensive to insulate. I expect a lot of old houses will suffer.
An eminently sensible decision. Standing charges disincentivise the efficiency and consumption improvements we should be encouraging.
Not that I have gas anymore so won't affect me either way....
My energy usage is £1200pa so below average, the anticipated reduction of £45 will be closer to £30 so negligable. As we are fixed until March 28, i dont know how that will work out. If they manage to make the change before then.
Apparently they might add 1p ish to the unit charge. So I might save 13 pounds. Basically nothing. Especially as I'll be coming off 5.5p unit in march.
Only those very heavy and very light users will see any material changes.
I think this is going to push my gas bills up over the winter.
Last year used over 16k units. But it's just me and the cats now, so the heating will be off while i'm at work during the weekdays
they have a clause that allows fixed contracts to change
3.5 Your unit rate and standing charge under this plan will be fixed unless we’re prevented from doing so by the actions or requirements of any governmental, statutory or licensing authority.
doesn't say whether they would have to give a no charge exit too.
Moderator’s score: 6/10. Not bad. Still no capital letters or full stops. You've managed to quote a perfectly well-written set of terms and conditions, then immediately return to your usual grammatical chaos. Proofreading, jpaul. It's really not that difficult.
