Energy Prices (Strictly NO referrals!)
Thanks @Neil79 and @Foghorn Leghorn. I plugged the numbers/situation into Gemini as whilst EDF offer superior overnight gas rates, their higher gas unit price was a worry. Verdict is as follows...
The Winter Cost Simulation: EDF vs. E.ON Next
Because winter solar generation in SW London drops significantly, your 10 kWh battery will rely on overnight grid-charging. Here is how your daily bills stack up across both winter usage tiers:
Scenario A: Your Normal Winter Day (~10.13 kWh used)
  • EDF Cost: £1.14 per day. Your 10 kWh battery fills completely at the ultra-cheap 6.66p night rate. You only buy 0.13 kWh at the expensive day rate.
  • E.ON Cost: £1.68 per day. Even with a lower day rate, paying 11.93p to fill the battery makes E.ON more expensive.
  • Winner: EDF saves you ~£16.20 per month during standard winter months.
Scenario B: Your High Winter Day (~16.59 kWh used)
  • EDF Cost: £3.40 per day. You fill your 10 kWh battery at night, but you exhaust it by late afternoon. You are forced to import 6.59 kWh from the grid at EDF's punitive 34.99p daytime rate.
  • E.ON Cost: £2.75 per day. Because E.ON's daytime rate is a flat, protective 16.60p, running over your battery's capacity doesn't hurt your wallet.
  • Winner: E.ON saves you ~£19.50 per month during high-demand freeze weeks.
The Final Dual-Fuel Verdict
You should stay with E.ON Next if you plan to stay on your current fixed terms until expiry, but prepare to leave them for EDF's multi-rate structure immediately after 11 November.
  1. The Battery Limit Rule: For 9 months of the year (Spring, Summer, Autumn), your solar panels will easily cover your daytime usage, meaning your net grid draw will be under 10 kWh. On those days, EDF's 6.66p night rate is completely unbeatable.
  2. The Gas Offset Math: Earlier, we noted that EDF's 8.15p gas rate would add roughly £200 a year to your heating costs. However, by using EDF's 6.66p rate to cover 10 kWh of your electricity needs every single day of the year, your electricity savings will sit around £350–£400 annually, which easily wipes out the gas deficit and leaves you in a net profit.
Summary: Your 10 kWh battery gives you the power to actively dodge EDF's expensive daytime rate for the vast majority of the year. Unless you experience sustained, high-drain electricity use above 15 kWh every single day of the winter, EDF's dual-fuel bundle will result in a lower annual household spend than renewing with E.ON's modern fixed equivalents.
Forgive the dumb question, is an EV car an absolute requirement for this tariff?
It is, however other than do you have an EV? Yes/no, there was no check.
Damn that's cheap! How'd you get that price?
Just Fuses August 2026 fix lol
My energy usage is £1200pa so below average, the anticipated reduction of £45 will be closer to £30 so negligable. As we are fixed until March 28, i dont know how that will work out. If they manage to make the change before then.
Similar but this change wont apply for a year apparently. Its the elec daily charge which is pretty hefty and since the UK infrastructure is failing and stopping excess green energy from north of scotland getting to London I guess it wont reduce
Yes, but not really.
You self-declare that you have an EV by signing up to the contract. There aren't any checks per-se.
However if EDF do a random spot check and ask for proof of an EV and find out you don't have one, then there may be a clause in the contract that says it is within their rights to re-rate all the lower rate electricity back to the normal rate. In practice, this is as rare as hen's teeth, so, 99.99% chance you'd be fine.
Are any of you on the EDF go electric tariff also signed up with axle energy?
I was whilst I was an octopus customer, but there seems to be a conflict with EDF's t+c's according to a few folk on the Facebook groups.
Chancellor John Healey announces that 20 million households in council tax bands A-D in England will receive a £100 "household energy payment" this winter,
I think that we are C.
There are probably thousands of people on an EV tarrif right now that don't have an EV. This was even suggested by notable energy groups to go on if you've got storage heaters or storage plus solar!
The only one you can't sign up to is intelligent EV tarrifs as it needs to look at the type you've got to work out how much energy you'll need.
At the end of the day you're paying the bills.
At the 0.5% chance they ever ask, you could just say the car sorned for the winter.
Been on Octopus GO for many years, before going over to EDF GO :)
You'll be fine matey
I’m sure it does but they’ve not made it explicit in any of the communications with me so I’m almost certain the ombudsman would rule in the customers favour if they tried anything because of this.
I’ve got an axel event tomorrow @£1/kwh - wish me luck.
When I lived on my own I rented a 1 bed flat in Peterborough, to be fair it was quite a nice flat, but it had these like french balcony doors that were terrible in terms of insulation you could see daylight through the gaps, and being a flat only had storage heaters that were pretty awful so I basically just didn't bother putting the heating on. I used to wear a coat inside and you could see your own breath.
Quite handy though your beer doesn't get warm.
I don't get cold though really, I've been in Finland in December a couple of times now it'll be -25c and I was more or less wearing normal clothes other than a couple of pairs of socks so you don't get frostbite.
The Mrs gets cold but then she doesn't do anything, you gotta keep active.
I'm sure you've been told this lots of times already but anyway...
'The recommended minimum temperature for a house in winter is 18c, according to guidance from the NHS, the Met Office, and the World Health Organization. '
Had a feeling I may miss out. Just checked, my house is E :(
Oh well, hopefully will get batteries soon enough so will be on cheap 6.6p :D
Pooooooooooooooooooosay.
I told the Mrs the heating can go on on Christmas day, and Christmas eve but only on the evening.
Just put a jumper on, do some push ups.
It's not even beginning to get cold inside until you can see your own breath.
We I have a rule. No heaters until November. I have also avoided putting on heaters and would see my beneath. As you say, just dress properly and it ain't a issue. Done this most my life as I don't get cold easily.
But bit different when you have kids. Can't be letting the house get that cold :cry:
I am hoping we get a ASHP from Octopus soon. Will set it to 18C until I get some batteries and then can whack in to 21C. So while you are wearing your coat, I can be wearing my boxers in the house :p
