**** The Official Chinese Phones Thread ****
I ended up cancelling my honor magic order as it wasn't shipped out for delivery today. Now got my eyes on getting honor win rt2 for all day battery life 12000mAh battery on Snapdragon elite gen 5. Whether it manages the battery life that well is a different question, but should be fine based on tests I've seen on other phone.
Then I'll look into my alternate phone be it a foldable 2nd hand v5 or V6 or Xiaomi 18 pro max etc
Turns out it only outdoes the Honor Win 2 by about 30 minutes, so the latest chipset is better optimised even with nearly 2000mAh smaller battery.
I was hoping there would be a major difference of an hour or two to justify the difference more, guess not if you're doing demanding tasks, perhaps more so if you just want it on standby.
Now I've got the x Fold6 the search continues for my normal slab phone options to abuse the battery life at work 24/7 and exposed to the elements more.
Well, I've found my 1st major problem with my Find X10 Max Pro, the AOD display isn't AOD ! It turns off in the dark !
I use my phone to display my blood sugar levels (I'm diabetic) at night, it worked perfectly on my Samsung phones but the OPPO AOD turns off if the room is dark...
OPPO , when Always doesn't Always mean Always :mad:
Turns off when room is pitch black. At least it does that on the ultra. I agree it should have extra settings that keeps it on indefinitely.
My gripe is it's too bloody bright in dark environments. My Pixel dims it to the correct levels, silly oppo doesn't.
It's a pain in the ****. I'll have a dig around on XDA, maybe there is some ADB shenanigans that can sort it.
It doesn't turn off for me on my X9. Make it set to all day in the settings.
Went for a 14 pro 5G in the end, £159 on AliExpress today and £112 if the cashback actually gets paid out. Can't say no to that, just got to make sure it supports esim but I believe it's the global version.
Yeah should do if it's global but if it doesn't get this from rainforest -
V3 Flagship eSIM Card & Reader Kit, Universal SIM-eSIM Adapter for All Smartphones & Android Devices, 1.5MB Storage, 50 Profiles, Premium STK Chip, Pre-Cut for Global Travel USA/Europe/JP/China​
Hopefully I won't have to but nice to have the option, thanks!
Just ordered the Oppo x9 ultra, Oppo are doing £300 off at the moment for a few days. Traded in my s26 ultra for £661 which is reasonable given where we are in the cycle.
Was looking at the s27 ultra but it looks like a very average upgrade to battery and camera, will be intrigued to see if the x9 ultra is as good as the claims.
Cost of the swap is £489 which is not too bad
There’ll be things you miss from OneUI but overall the X9U is a brilliant device.
Thanks, look forward to trying it out as all the long term reviews have been very good. My biggest concern will be whether I can live with ColorOS.
I'm used to PixelOS or One UI but it's good to try new things , worst case I sell it on and end up with an s27 ultra in a few months
ColourOS is pretty sleek. A few annoying things,but most OS’s do.
Had the Oppo Find X9 Ultra delivered yesterday and so far very impressed, cAmeras are a step up from the s26 ultra . Early days but battery life appears like it may be amazing.
Having always had the s2* Ultra phones or Pixel Pro XL this seems like a step up , reminds me of how Samsung used to innovate .
Really glad I decided to give it a chance, my biggest concern was the OS. Glad to report ColourOS 17 seems less intrusive then OneUI and you can remove nearly all the bloatware , couple of things missing from Good lock I used to like but nothing I cannot do without. OS is very fast and customisable out the box which is nice .
