RGB Fan control software
9 Feb 2004
wales
Hi guys
I am building a gaming pc for a friends 11 year old son. The case is going to be NXZT H5 flow with Arctic Bionix P12 A-RGB fans.
I normally use Fancontrol which is fine on my pc, but as it contstantly needs updating, it might cause issues on a kids pc. I also really dont want to install Armour crate for the RGB control.
So im after some help with what prodgrams to use for both fan control and RGB control. I dont mind messing with the fans in the bios but I need the RGB to be easily controlled by the owner.
Thanks
Gwyn
Signal RGB free version
Best RGB software there is
Believe the latest update now includes fan control too
Open RGB would be next choice just for RGB
Got 7 different manufacturers stuff in my pc
Signal RGB controls them all
Perfect thanks, will give that one a go. Thanks for your help.
honestly, just get a remote control RGB hub (or a hub that uses the reset button to cycle the modes)
for all the computers i've built for my friends' kids...it's always been the KISS option
no software no messing about
Also a good call, thanks
Would also suggest
Make an image backup on flash drive
Something like macrium PE
So you have the bootable environment and
The recovery image on one flash drive
Free version of macrium can still be found
And sooner or later kids tend to do something that
They shouldnt
Or do a hidden recovery partition
Basically something that restores it easily
So you don't have to do a role as IT support
Not just icue
Another software controlling rgb
But signal rgb does have the options
Close conflicting software/process
Or dont close it
So it's possible for example to use signal rgb
For leds
And use lian li L-connect for fans
Though I did.that before signal rgb could do fans as well
Signal RGB is a great but of software I was a bit weary of it at first as I was used to armour crate.
Signal rgb as above word of caution tho it conflicts with corsair icue if you use anything from corsair
The earlier versions were good as they didn't conflict with each other, then the signal RGB Dev's decided they didn't like that and stopped it working with icue.
