EV general discussion
We are currently in a bit of a Mexican standoff after our test drives, Mrs Sk8 is in team Smart #5, I'm team Polestar 4.
I guess we are getting the Smart.... :cry: :cry: :cry:
I'll see how we go for the next couple of weeks
I have this every single time with my wife. Then every single car I get she ends up wanting. Didn't want an auto under any circumstances, now will only drive an auto. Didn't want an EV, now I look out on my drive this morning and my EV has disappeared.
I've done over a 1000 miles now in mine and really got used to it. Full ipedal mode as there's very little traffic on my commute. Really nice drive once I turned down the forward collision a bit, it kept giving me whiplash passing parked cars down my street. I've embraced all the other bings, bongs and lane assist. I've found it really really easy to speed so I've left it all on.
This reminds me of the debate we had about what pet to get. I wanted a cat and my wife wanted a dog. We discussed this at length for many months and in the end we agreed to compromise and get a dog.
It's that rug, keeping everything nice and toasty to stay efficient...
Doubles as a scarf so you can have the heating set lower :p
I also have my cabin temperature set to 18.5 in the i4 but partly because that’s already really warm for that car. In the X3 I’ve got I need to set it to 21 to feel comfortable.
Don’t get how they can all be different
Does the i4 have double glazed or acoustic glass? Reducing the frozen radiator effect of the glass area has a massive impact on how warm it feels in the car. Part of the reason why my office at work feels cold even when it it 23'C air temperature is the draughty rubbish aluminium window frames and single glazed glass right behind me.
My rebuttal to this is how often are you changing the temperature in your car? My car is set to 21.5c (the .5 is important, OK) all year round.
Failing that, I expect this depends on your car for the experience, but the voice control works perfectly fine if I want to adjust it without faffing around.
An odd number....and a 0.5c also...... There's a special place in hell reserved for your type......... :D :D
It’s only important for me due to with travel. There can be times where I’m doing all my miles in a day or two without the ability to stop somewhere and charge, so maximising the range is key.
The ID 7 motor was the newer, more efficient variant. I believe the i4 isn’t hugely efficient.
It’s really down to how you drive and what types of trips you mainly do. But clearly your i4 being less efficient than you ID.7 is not a deal breaker. So ultimately for you and I would say the vast majority, relative EV efficiency is largely irrelevant.
I suppose financially it's irrelevant at current electric prices, but it does impact ultimate range which is a consideration for some. Greater efficiency is no bad thing, especially as it can allow for smaller batteries etc.
Only time it bothers me is if it's the difference between needing a public charge or not, if I can avoid it by driving a bit more sensibly then I will.
I have the same when running on petrol though, especially since getting a PHEV.
Do I set the cruise at 70 and know I'll make it home without refueling or do I risk it at 79 and then have to bail out annoyingly close to home and pay OTT for the privilege?
The older I get the more I opt for the first option! Being a PHEV simply means I can run the tank down more as I'll have 30 miles in the battery the following morning so I don't have to factor on getting me to a petrol station.
Not sure why I started investigating it but I always assumed my garage was on 4mm cable as it is on a 32A breaker, turns out it is on 6mm so getting a charger fitted just got a lot simpler.
My wife thinks we should just consider getting one now anyway and use it for my PHEV, which would open up more tariffs. Her logic is that we will need one during the next 10 or so years we will be living here anyway. Guess she has a point.
But that’s the fringe case I’m referring to. It’s a sliding scale depending on need and weather. It’s the ultimate sliding scale of “yeah but what if”.
It’s kinda like comparing 170mpg to 140mpg cars.
Depends on the situation and circumstances
With the i4 I’ve had to adapt how I use it to make it last in situations where I need it to - sometimes sitting at 56 behind a lorry on a motorway.
I never had to think about it with the ID 7.
I wouldn’t say irrelevant because if the i4 was any less efficient, it would not be a suitable car for me. As it happens I’m already adapting the way I drive heavily, and I’m not heavy footed – I would get 5+ miles per kWh in it during the summer on the same journeys I do now. Average was around 4.7.
In July and August, the i4 averaged 3.9 driving at 60 max and eco pro all the time.
Hah, rookie. My wife and I have been arguing over what car to get for around three years. She wants something small, cars she wanted was a Q2, A1, Lexus LBX, etc. I'm 42 and way, way beyond driving a first-drivers car. So we both compromised and we're picking up a Tesla next week.
Hah, suck it woman.
So like I said, not a deal breaker?
Is it an i4 40 or 50?
Hah, suck it woman.
She will have the last laugh when she scrapes the side and tells you she wanted a smaller car.
