9070xt
Poor decision picking the wrong GPU that's what I meant and wanna rectify that even if it does cost me it's my mistake and my choice.
Maybe not but will get more out of then9070xt than I will 5070 for higher settings etc surly
To be honest I would have thought that you won't lose to much in the swap and having 16GB it's worth it for the future. They really are great gpus
You've already admitted earlier in the thread to making poor decisions and that you're still paying the finance off.
As a casual gamer you're going to notice very little difference but you do you I guess.
I'd probably say it's more than very little difference.
"Across our 52-game average, the 9070 XT is comfortably faster than the RTX 5070. It delivers a 24% higher average frame rate at 1440p, with that advantage increasing slightly to 25% at 4K. The Radeon GPU also delivers substantially stronger 1% lows overall."
Is OP going to notice that difference without a frametime graph as a casual gamer?
Is that also factoring in DLSS etc as it still has advantages over FSR4.
Wrighty's definitely doing it now :D
I brought the Asus 9pu0xt prime OC pulled the trigger
I'm assuming that's the 9070XT and your fingers are just trembling with excitement :cry: .
Congrats on the new card.
By the way, when downloading the amd adrenaline software I'd download it manually. if you allow it to download via auto download, it's failed to download properly for me. i end up with old drivers and the update button doesn't work...for some reason if I download manually, it's all working fine. May just be me but happened more than once.
anyway, have fun playing. Also fun playing around with the overclock/undervolt
Yeah but it's cause I was walking and typing lol so yeah 9070xt I will note that a d make sure I do it manually thanks for the heads up.
Any undervolt suggestions or see how it goes
It's Arrived a
Sorry, been a bit tied up with work. Tbh, my pc is in bits as raided it to build my sons pc when realised I'd taken parts back home to uk and was building where i work(work abroad). Anyway, I'd just see how it goes and experiment. I bought 3d mark on steam and just ran timespy for baseline, then started messing.
the place you want to be is here in the adrenaline software. set to custom. start by lowering the voltage offset(below just an example), and pushing the power limit..you can increase the memory timings too and the max frequency offset
I'd start justr doing a -50 voltage offset and go from there.
My original nitro+ was rated as excellent but used it for a friends build when prices spiked. Managed to replace it a month or so later but the new one wasn't on a par. this pc I'm on is my sons build so not messing with it. just keeping it clean for him.
I also used in game benchmarks..managed a stellar score on returnal i remember...you wouldn't be able to play the game with the settings as the benchmark was jerky and I thought it would crash, but it passed the finish line and the score was stellar. i still managed to get as setting that gave me a 10%+ fps boost that was rock solid
there are others on here far more qualified than me with this stuff, but trial and error for me..part of the fun
ps. nice haribo collection...I got something similar when i ordered a couple of scopeII 96 keyboards. Top marks to OCUK atm
enjoy the new card
