Anyone had micro suction ear cleaning?
9 Dec 2009
Bristol
Thinking of getting it done and wondering if anyone's had it, how did you get on?
I'm a bit Mutton Jeff anyway with slight hearing loss in both ears and I use ear plugs regularly when swimming. My ears seem clean when I use a cotton bud on a stick but maybe the earplugs just push the wax further in.
Yes, I had this done several years ago.
IIRC, before having the treatment, I was advised to soften the wax with olive oil for a couple of weeks.
As I recall, it tickled when having it done which was quite pleasant, and I could definitely notice a difference after the treatment.
I should really get around to having it done again.
Yes I was told the same about the olive oil. Glad to hear that it was a pleasant experience rather than painful! Some people have said getting ears syringed with water can be painful.
I thought I was going for micro suction but it was just blowing in water using a special device.
Hopefully you get the micro suction experience but I think either should be effective.
Yes, every two years for the last six years. Definitely use olive oil for seven days beforehand once a day in each ear, cos it makes it so much easier. I bounce out of there every time, feeling like I am floating. And please stop using cotton buds, that's a hard no and could be making it worse. I pay £30 per ear and it takes 5-10 mins all in.
E: get Cerumol from Sainsburys once cos it includes a pipette/dropper thing, then get a big unbranded refill from Superdrug.
Plenty of times and it’s amazing.
First things first, go into your bathroom and throw away those cotton buds right now.
If you’re putting them deep enough into your ears to touch wax, then you’re compacting the wax more and making things worse. The smallest thing you should put in your ears is four elbow!
Do a solid week of olive oil, you can get a spray olive oil with a special ear tip which makes application easier.
As the surgery no longer does water irrigation and the local specsavers swore that my ear canals were too narrow for micro suction, i brought a private nurse into the house and she used a combination of the two methods, sixty quid for one ear and eighty quid for two, it was well worthwhile.
I have mine done every year or so. Been treated privately a few times with micro suction as our surgery used to use water irrigation which made my ears ring. They now use micro suction and last visit was fine so pointless spending £50.
Yeah, have had it done a few times at Specsavers, which went well with no issues. I find that using earphones seems to make my build-up worse, so since my last clean (around April), I've not used earphones as much and it's made a huge difference. My ears are still clean.
Use olive oil for 7 days as suggested above and book in an appointment at Specsavers or elsewhere that does micro suction wax removal.
Buy yourself an Otoscope off Amazon for £20 or so, and you can see for yourself if there's anything in there to worry about.
I have one of those but I can only fit it in my bad ear as it has a enlarged entrance. I needed one to check for infection which my right ear seems prone to since a huge operation 28 years ago.
I had several treatments of micro suction, weekly after the big operation I had, then monthly and six monthly after that for a couple of years. I am still supposed to have it annually but I don't bother because it has bad effects on me, nausea, extreme dizziness and I have passed out a couple of times.
I bought Smart Bud ear cleaner a couple of years ago so can check and gently remove it myself.
