Hmmm might try the Tesla with regen off...
Yeah, mines the old model 3 and I know it doesn't have the blended braking. Worth a try fwiw...If it’s not a Model Y Juniper, don’t. It’s the only version of Tesla that allows regen on the brake pedal.
No, only the Juniper model y at present.Doesn't the Highland do it too?
So I've had a bit of a headache today, ordered a Dash Cam + fitting from Halfords who knew I had an EV, then told in another thread that Halfords won't fit Dash Cams in EVs, rang up the Fitting Service and I've had to cancel the order
What pee'd me off is that the Halfords website knew what my car was and proceeded to the 'Choose A Fitting Day' bit.
ANYWAY
I understand that hardwiring can cause problems with 12v drainage in Parking Mode (According to Google) so can I buy the Dash Cam I want and just power it with the cigarette lighter or USB with no problems?
* It seems plenty have installed into MG4s and not reported 12v drainage while in Parking Mode.
I need some decent advice please.
I have front and rear in my polestar which Halfords fitted, it’s ran off the obd portSo I've had a bit of a headache today, ordered a Dash Cam + fitting from Halfords who knew I had an EV, then told in another thread that Halfords won't fit Dash Cams in EVs, rang up the Fitting Service and I've had to cancel the order
ANYWAY
Halfords in Gateshead team valleyMan from the Fitting Department says no, they will not fit it and won't even fit it from the lighter plug.
Which Halfords fitted yours?
Others on the Facebooks are also saying Halfords fit theirs, maybe they have new fitting partners now.
From Halfords site:
A bit of Google:
NoPresumably with no parking mode if you’re running off the 12V?
