Multiple back ups.
I’ve bought the prebuilt one at a good price. It has all the components that were listed by @Avalon. I’m just buying some HGST HDD. Thanks for the help and advice.
I’ve some other questions if that is okay. Would a SuperMicro AOM-TPM-9665V TPM Module (20 Pin 20-1) TPM 2.0 Trusted Platform be worth buying?
I thought that the Intel DC P4500 could be used as a Cache Drive.
Supermicro CBL-SAST-0631 Mini SAS SFF-8643 4x SATA Reverse Breakout Cable
I’m just trying to find the HGST drives. Which is quite hard at present.
I read the first few replies then a few from page 3 then a few more and thought I'd offer an alternative point of view from someone who hates complexity.
If you separate your Time Machine needs from your actual data, would a cloud storage box not be plenty enough? You could set an rsync up to do incremental backups every hour if you so wished and you could set it to backup just the media on that external drive you have (correct me if that's not the case). The biggest upheaval would be if the Mac mini went down, sure you wouldn't have a perfect restore of it but it's just an OS and a few apps, the external drives would hopefully survive and your backup is still very safe in the cloud. Even if the external wasn't reverse the rsync and pull the data back down, you'd be back up and running and it keeps stuff relatively simple.
Then you could run a relatively low end UPS (let's face it you only need graceful shutdown on a system that doesn't draw a lot) and your big spend is broken down significantly into a monthly running cost that doesn't involve buying outdated consumer hardware.
I’ve bought the parts to build the NAS now. But I may try and also run Jellyfin on it so that it has a dual use. The Cloud back up is also an option and it at least gives me another way to back up data. Regards a UPS. I’m still looking to buy one but I’m unsure of what model to go for. Thanks for the suggestions.
Hey you're learning, perhaps I was a little harsh.
You don't *need* a TPM module for UR, but the Ali-Express units generally work well enough IME if you are so inclined, same sellers on the other platforms at a higher price point/but sometimes quicker delivery rather than waiting a week from China. USB wise you can use internal boot, I much prefer the internal board port usually found on SM boards with something like the Sandisk Ultra Fit drives, barely stick out beyond the port, very little chance it gets moved/knocked, and performance is largely irrelevant for it in UR. If you are using a UPS, a decent consumer NVMe will work as you'll have a safe shutdown, U.2's can be a little more power hungry/hot IME, you also need a tri-mode capable controller (9400 onwards) for native support on an LSI controller, or a PCIe break out board/cable. If you do go with consumer, stick to a name brand drive (Samsung, Micron, Crucial etc. but avoid the Samsung U.2 enterprise stuff, it has issues) and make sure you update the firmware on w windows box before setting up, it's just easier, and ideally choose something with DRAM cache and TLC rather than QLC and/or cacheless. I've not looked up your chassis/HBA choice, but make sure it takes 8643 on the HBA end and not an 8087, if it's using a backplane, it's likley to be 8087 on the backplane end, if going dirtect to drive, SATA in supermicro terms would be CBL-0476L where as a 4 drive SAS breakout would be8643 or 8087 to 8482, I tend to use generic cables without issue from the usual places with next day delivery, but it's just China stock warehoused in the UK with a nice western friendly brand at a markup. Also, forward breakout...
Cloud (or any off-site) is a great additional layer, but as someone who had a *lot* of data off-site at one stage, your supplier can change the game overnight, i've used pretty much any provider worth using since the Streamload days, Amazon, Google, Dropbox, literally everyone who promised unlimited or decent cloud storage at a minimal cost pulls the plug, so now I have what's important replicated to at least two cloud providers, but anyhting local and recreatable is simply redundant.
Oh, and UR's BF deals should be live in circa 2 days if they follow the usual pattern.
Thanks. I’ll go through it and no doubt have some questions.
I was thinking of using the following HDDs;
I’ll order the USB you’ve mentioned as it sits in nicely and doesn’t warrant getting knocked.
I’m not sure what the a tri-mode capable controller (9400 onwards) for native support on an LSI controller, would be for? I may need your help and advice on that. This is the motherboard:
Would the Intel DC P4500 1TB U.2 NVMe PCIe SSD be okay for a Cache Drive? Or is there something more suitable.
I’ll have a look at the cables that you’ve mentioned;
I run quite a few of those drives, would 100% recommend. Check they have the cache enabled when setting them up though, OEM drives often have it switched off via firmware, but it’s literally a simple script to enable it on array start.
USB drive wise it’s just personal preference, but smaller is safer in this scenario.
Board has a LSI 2308 based controller, so in this case, it’ll forward break out a single 8643 to SAS or SATA depending on the cable/drives used. You can get SAS drives with an SATA interface from HGST just to make life interesting.
I also have a 4TB P4510 and 1TB P4511, really solid drives, with the kind of write endurance your grandchildren may have to worry about under normal usage, I just checked my P4511 and it’s seen 1.35PB of writes in 37 months of usage. To use a P4500 series drive, you will need a PCIe to U.2 adapter, or a PCIe to NVMe depending on the drive form-factor you choose - be warned, the P4511 is 22110 and not 2280 found in consumer drives, that extra 30 is 3cm of extra length and you need an adapter that will support that. If going P4510, it’s either a physical card you mount the drive to, or a simple PCIe to 8643 that breaks out the PCIe lanes direct to the U.2 interface. You have a PCIe 3.0 x8 slot which can do a maximum of 7.8GB/s so is plenty, the PCIe 2 x4 slot will cap at 2GB/s, but realistically it’s a theoretical limit in most real world usage. Will you find a better drive for that sort of money? I would suggest nothing will match the claimed endurance, be TLC with dedicated cache that has capacitor based backup etc. but you might be able to find something that offers slightly better £/TB in the consumer market. Just
In the UR ecosystem, it would make a decent cache drive, you’ll run docker off it and cache is the landing zone for your array pool usually. If you are using 2.5Gb USB 3 NIC’s, you are limited to 290MB/s ish writes to the box anyway, so can fill the drive in under an hour, but obviously you’d set mover to kick in well before that, or if you need to dump a lot of data to the array, do it without parity and then build parity afterwards as cache to array writes will be near full single drive speed.
The cable you linked to won’t work with that board, and if you are running SAS drives, you need to break out to SAS if going direct to drive, or the appropriate connection on any backplane (usually 8087 in this generation). If you end up going SATA, you already have a load of those onboard anyway.
Thank you.
If I went for this as a Cache Drive.
Would this card be suitable:
Well, that escalated quickly.
You could use that card, it is a 9400-8i will support NVMe/U.2 drives, but it’s also £100, which as you already have a load of SATA and a SAS port onboard, seems like it may not be needed unless you are planning on adding a lot of drives. Same card can be had for a little less direct from China. The other option is a single drive card for £15 ish if you search for ‘U.2 PCIe 8639’ on any of the usual places. Which you choose is down to where your plan/budget leads.
No problem. I guess I’m just trying to plan ahead as much as possible. I’ve ordered 4 of those HGST 10TB Drives. Intel Series P4510 As a Cache Drive. Would it be a safe bet getting the 4TB over a 2TB. As prices vary online.
