EV Dilemma
Ok-ish. Ride is quite firm.
yes, and if you have sciatica that probably dismisses that plus the older model3, and the i3s as cliff had found
Megane e-tech should be in budget, but probably too small like an ex30 would be (even if they have legendary volvo back friendly seats).
Currently own a Honda E and a 2021 LRDM Polestar 2, so my 2c
An early Polestar 2 will be a much better fit than your Honda E. The seats go nice and low and offer a decent driving position. I'm just shy of 6ft and never get the feeling of being cramped in the Polestar. Maybe the panoramic roof helps with this? Efficiency wise the dual motor Polestar is worse than the Honda E, but I still get around 170miles in the winter, and around 220 in the summer. Despite the power differences and book figures, the Honda feels quicker low down compared to the Polestar. The Polestar throttle map is relaxed unless you purposely push on, but when you do it hooks up really well. One spec'd with the Plus and Pilot packs will also give you the pretty much the same creature comforts as the Honda (adaptive cruise, 360 camera, heated seats and wheel, but you'll lose the heated windscreen) The Polestar app is also much better than the Honda one. Oh, and you'll miss the turning circle of the Honda, everything else feels like a tank in comparison!
How would you know?
So you can see why some of us own the Honda E then.... its just cool.
Do you find there is more room in the Polestar than the Honda E then..
I just wish I had more room to stretch out and legs being a bit more straighter... The only car I've had to pull the seat forward in was an Astra GTC..... the MX5 was tight but at least my legs were straight....
I get the seat height would be more advantageous but I still need the legroom...
Tbh, with your stringent requirements (not through your choice I must add), you really need to sit in one and test drive. No amount of suggestions can replace physically being in the driver's seat and making sure it fits your requirements
Being only 5'7" legrooms not been an issue, but i can confirm that an i5 BMW does have the ability to go far enough back that i can't touch the pedals after loaning it to my 6'2" mate!..... :D :D
I'm 6'3" on a good day and 82kg. I would say a Polestar 2 is a tight fit, yes the seats can go very low but the centre tunnel angles out towards the dash/screen and can hit your knee, clearly designed as a left hooker. Also, depending on how large your feet are you can hit the stalk behind the peddle.
Worth a try, they're great cars and I think mine is brilliant but it's not without fault.
