Changing console font/screen size
Man of Honour
4 Nov 2002
West Berkshire
I have just got myself a nice big monitor, and as with my Mac, I'd like to adjust the resolution on my Linux box (console) for a better fit.
Is there a command I can use to change the console height (lines) and/or width (columns), and/or the console font?
Thanks.
Yup - real, honest to goodness commandline. You don't think I waste folding cycles on a GUI now, do you? :p
OK, that's the font. Any ideas on the text size (it's a bit big right now - so more lines would make sense). :)
I just used Google to find that link. Some creative Googling of your own might throw up some more help. Or wait for Billy - I bet he will know.
I've seen it done via the kernel framebuffer but I'm not sure exactly how to do it. I'll have to research a bit.
EDIT:
Try appending
fbset -a "1920x1080-75"
or whatever the resolution you desire is to the end of the kernel image line in your grub list.
Tried the framebuffer, but for some reason my ATI drivers don't live well with it, so on the rare occasion I do want a GUI the system freezes. It's supposed to work but I cba fixing it right now as I'm switching to nVidia soon anyway.
If I want a high-res console then I boot with "video=vesafb:1600x1200-32@60" or some such in my bootloader (vesafb-tng, Gentoo), but I generally use VGA text mode console in 80x50 (vga=3841) as its much faster :)
In Arch, I have added in the kernel line of grub vga=773, which gives me a 1024*768, 8 bit console, but you could quite easily use 775 for 1280*1024, 8 bit or 796 for 1600*1200, 8 bit.
You can have 16 bit and 24 bit as well - but why would you?!!
well some programs like links and mplayer can make full use of a truecolour framebuffer without having to run under X :)
hehe... or maybe more realistic ascii pr0n in lynx?!!
Oh yes, viva la ascii pr0n. :D
Anyway, all of this seems to rely on vesafb or some other fb, which seems to not like my setup as stated earlier. I'll try again when I have the inclination (it's not the end of the world). :)
I got the console framebuffer working (figured out what I did wrong last time). \o/
Only problem now is I can't get X into a widescreen mode, no matter what settings I throw at it. :( :confused:
