Is this ram ECC?
Caporegime
9 May 2004
Leafy outskirts of London
I have a 512MB stick with the following info on it:
Sticker reading:
512MB PC-3200 DDR
(38) 400MHZ 070731
Warrant Void If Removed
Chips reading:
Samsung 530
K4H560838E-TCCC
ZKA154BJ Korea
I wanted to stick it in with my 1GB of OCZ Non-ECC stuff, but some google hits say this is ECC. Any way to be sure?
Does it have extra chips in the middle of the RAM? Every ECC stick I have seen has a couple of extra little chips in the middle.. The Error Checking Chip! :D
Take a photo if you aren't sure what I mean and I'll tell you. :)
Why do you use ECC for servers and not gameing rigs then?
It's not suitable for gaming really as the ECC adds extra RAM latency, which hurts gaming performance.
There was that AMD incident though involving the Socket 940 FX series chips, which used ECC DDR as they were on server motherboards. Back then the performance drop was negated by the fact that everything else AMD was on single channel (Socket 940 FX-chips were dual-chanel).
Once Socket 939 launched the 940 FX chips were discontinued and sunk into the wilderness.
Seems to do fine running at 2.5-3-3-8 as my old ram does, shaved 1 second off my 512 and 1MB SuperPI scores too :)
